Arexx and includes
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    I'm currently working on some Arexx code.
    And by now I'm having ~500 lines. So far it's still OK. But there will be some more code.
    Basically much could be extracted into some sub modules.
    I'm not aware Arexx has a concept for including/loading other Arexx code.
    Or? Can this be done somehow?
    Manfred
  • »14.04.16 - 18:07
    Posts: 845 from 2007/10/23
    easily:
    call submod1()
    will load submod1.rexx
  • »15.04.16 - 10:35
    asrael22
    Hmm, yeah, that works, kind of.
    A script 'submod1.rexx' is loaded and executed upon call submod1().
    But when there is a internal function marked as PROCEDURE I'm getting an error: "Invalid PROCEDURE".
    Removing the "PROCEDURE" from the function doesn't produce an error but the function code is executed as well which is önot really wanted.
    Any advice?
    Manfred
  • »15.04.16 - 12:03
    Indeed, an external procedure is not allowed. What do you mean by "executed as well"?
    > rx main
    FUNCTION 1 SUBMOD1 Work:Developing/submod1.rexx REXX REXX
    COMMAND 0 main Work:Developing/main.rexx REXX REXX
    /* main.rexx */
    call submod1()
    call submod2()
    exit
    /* submod2 internal */
    submod2: procedure
    parse source s
    say s
    return
    /* submod1.rexx */
    submod1: /*procedure*/
    parse source s
    say s
    return
  • »16.04.16 - 14:26
    asrael22
    Ah, now I got it.
    In main, call submod1() loads a file submod1.rexx and executes any global operation plus it executes the first function it finds.
    However, other functions in submod1.rexx are not visible from main. Can you confirm that?
    Manfred
  • »17.04.16 - 09:01
    Right, it's more like chain in BASIC, not linking in C.
  • »17.04.16 - 09:58
