Is Objective-C available on MorphOS?
    asrael22
    Posts: 451 from 2014/6/11
    The compiler itself may not be the biggest issue but the GNUStep runtime.
    Someone working on that?
    Manfred
  • »24.01.16 - 09:38
    Posts: 845 from 2007/10/23
    unlikely, go on!
  • »24.01.16 - 19:43
    kamelito
    Posts: 103 from 2011/9/21
    We currently don't know I suppose, Objective-C is not enough we need the API that goes with it.
    Itix wrote that a new programming language was under work IIRC, who knows which one.
    Kamelito
  • »24.01.16 - 19:49
    asrael22
    Swift would be the burner. But unlikely I guess.
    Manfred
  • »25.01.16 - 05:33
    Posts: 3332 from 2003/3/5
    The Synergy server bundled with MorphOS was written in Objective-C.
  • »25.01.16 - 07:03
    asrael22
    Really? MorphOS comes with a Synergy server bundled? Or do you mean client?
    Manfred
  • »25.01.16 - 07:26
    asrael22
    OK, I have found a Portable Objective-C compiler (http://users.telenet.be/stes/compiler.html).
    A MorphOS pre-built binary is available on Aminet.
    But this does not contain the GNUStep runtime.
    If Synergy server is done in Objective-C and this was compiled for MorphOS I'd really like to know more.
    Hard to find anything though.
    Manfred
  • »25.01.16 - 07:53
    Both gcc 4.4.5 and 5.3.0 supplied with the SDK come with objc support enabled and a port of the GNUStep runtime (although incomplete).
  • »25.01.16 - 08:01
    Posts: 650 from 2004/4/15
    Concerning the new language: I guess that "Lua" is the answer.
  • »25.01.16 - 09:09
    Posts: 12547 from 2003/5/22
    Was introduced with MorphOS 3.8.
    "Applications/SynergyServer [NEW]
    The new MorphOS Synergy Server allows you to control mouse and keyboard of other computers in your local network running a recent Synergy application.
    http://www.morphos-team.net/releasenotes/3.8
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=11169&start=58
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=11213
  • »25.01.16 - 09:36
    Wish I could tell you more, but this stuff ain't ready yet. Hopefully with the next SDK release...
  • »25.01.16 - 11:12
    TheMagicM
    Posts: 1220 from 2003/6/17
    Maybe one day, Synergy will be working for Linux..until then, its useless to me.
  • »25.01.16 - 12:40
    And why wouldn't it work provided you use the correct server/client version on Linux? I'm unaware of any issues there really.
  • »25.01.16 - 15:30
    TheMagicM
    Ok..last I remember you said something needed to be fixed for it to work under Linux but you didnt like Linux and therefore didnt feel like fixing whatever it was. I'll re-test and see if it works.
  • »26.01.16 - 00:32
    From 4 months prior to MorphOS 3.8 release:
    "Linux servers will be supported in the upcoming MorphOS release"
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11045&forum=3&start=10
  • »26.01.16 - 05:50
    TheMagicM
    Man..this is exciting as hell.. fixing to test in a few min..
  • »26.01.16 - 18:02
    TheMagicM
    Synergy works as a server on morphos and linux as a client, but I'm not interested in it that way.
    I want Linux as the server so I can use its kb and mouse and MorphOS as the client. I get
    2016-01-26T17:12:04 WARNING: client "MorphOS" has incompatible version 1.5)
    /tmp/buildd/synergy-1.3.8/src/lib/server/CClientProxyUnknown.cpp,248
  • »26.01.16 - 21:12
    The synergy you're using on linux is very very old. You need to update.
  • »27.01.16 - 04:52
    TheMagicM
    working on it now. I liked that it worked from MorphOS to Linux.
    EDIT: Works PERFECT! Man...this is very very cool!
    [ Edited by TheMagicM 27.01.2016 - 17:38 ]
  • »27.01.16 - 18:08
