Why not older PS3 OtherOS as target?
    Jupp3 wrote:
    vox wrote:
    But in year or two it will be 100e power station
    that can do more then most of Mac IF programmed well.
    In year or two, you can probably still buy a G5 Mac for less-than-100e, that will run circles around Playstation 3 (would run even more, if there was SMP support)
    Of course, PS3 still might be able to do "certain small things" faster due to SPU (assuming it was supported at all), but as mentioned before, unlike SMP, that would need to be specifically supported by programs.
    OR, you can live in the US and buy them for $100 right now (no I am not kidding).
    It makes buying other hardware to run our OS a hard sell.
  • »11.01.14 - 23:26
  • vox
    vox
    Posts: 616 from 2003/11/24
    G5 is rare beast to find. Thanks everyone for VERY INFORMATIVE LESSON ON CELL.
    I still do believe files can be merely compoled for cell and Altivec units (SPEs?) and great multimedia results coupled with nVIDIA could do the magic. It would be about time that one Amiga like OS starts to support at least one nVIDIA chip.
    If 256MB XDRAM limit could be overbridged, Blue Ray support introduced and virtual memory as SWAP partition introduced (why do I smell linux) end result could be both great console and great multimedia showoff for MorphOS.
    Not that I am forcing anyone, can aid it only via donations and hope.
    ARM and x64 route mus be long and its far better idea then PVR Semi and Freescale support that will be just in hundreds. Or you wish power, so quad core X5000 as I hear these days, should be target that MIGHT overrun the famous or infamous G5
    Cell actualy is newer and more modern design then G5.
  • »12.01.14 - 00:06
    Posts: 12533 from 2003/5/22
    > I didn't see the OS4 crowd talking about the e5500 core several years ago
    That's because you didn't look :-)
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=31890&forum=33&start=140#567042
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=31907&forum=33
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=31896&forum=33&start=160#569642
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=32910&forum=33&start=40#593765
    > we have already moved to 64bit processors, and the OS4 community is about
    > to adopt the same.
    OS4 was on the PA6T way before MorphOS was on the PPC970.
  • »12.01.14 - 00:19
    Maybe where you live. Other parts of the world seem to have better availability of used G5 Macs.
    Auto-vectorization (AltiVec, Cell SPEs) and auto-parallelization (Cell SPEs) doesn't really work well with most compilers (including GCC 4). The programmer still has to use his own grey matter for this and write the optimized code himself.
    AROS has 3D support for several Nvidia GPUs since 2010:
    http://en.wikibooks.org/wiki/Aros/Platforms/x86_support#nouveau.hidd_.28nvidia.29
    It can't.
  • »12.01.14 - 01:30
    Yep, completely forgot about the PA6T.
    64 bit, thanks Andreas.
    And I never really thought to look at AmigaWorld.
    As to Vox's contention that the Cell is more "modern" than the G5, well it is newer.
    Its in order pipeline is a lower performing legacy of older devices, and many of the other features reflect ideas that didn't pan out (XDR ram, SPEs, etc).
    And we are not really comparing processors, we are comparing whole systems 9where the pS3 really loses out).
    BTW - why is this discussion continuing?
    We know that a port to this platform is "never going to happen".
  • »12.01.14 - 02:53
    Jupp3
    Posts: 1193 from 2003/2/24
    minator wrote:
    However the PS3 has long since been completely hacked, so the Hypervisor is no longer a problem and there are no limitations to accessing all its hardware. It could be supported fully but it would be legally dubious to say the least.
    nvidia won't be supported (fully). That statement has been continuously given by the team. Or at least there are no current plans to support it, of course there are some SENSIBLE reasons (aka "Not PS3") to support it, such as some iBook & PowerBook models having it built-in.
    Don't expect G5 performance.
    Yep. Better buy a G5 with supported gfx card instead, and expect (single core) G5 performance :-D
    The "difficult to program (TM)" SPEs are really just souped up AltiVec units with their own memory. If you know about threading, double buffering and AltiVec, you can program an SPE. Most people who have actually programmed them did *not* say they were difficult to program - I spent a year working with people who wanted to sell Cell workstations so I know exactly what people said about it. I suspect the whole "difficult to program" is really just FUD from a certain large semiconductor company who had nothing to complete with it!
    Yes, I know Altivec is easy to program for (I got the official documentation books from Freescale) and SPE shouldn't be much different.
    MorphOS has supported Altivec for a long time, and the majority of userbase has Altivec-enabled system. That means that every program out there supports Altivec by now, right?
    What, no? Why?
    No matter how "easy" it would be, it would have to be done. It's always easier to just compile the code (mostly) as-it-is for MorphOS, and release.
    Nowadays most code is coming from "outside" (open source linux projects), and there higher end(G4+) PowerPC has really been going out-of-fashion lately... So not many projects bother adding any support, and neither do people who port them to MorphOS.
    Also, Altivec is good for very specific tasks, if the program doesn't do much of that, there's no point of adding support.
    And now, if there was also SPE support in the OS, and very small minority of userbase would have capable systems (as most would want a better system, such as Efika), how much less point would there be to waste time optimizing?
  • »12.01.14 - 10:46
    Where did you look for discussions by the OS4 crowd then? When it comes to English-speaking sites, Amigaworld.net is one of the 2 top sites (the other being amigans.net) for OS4-centric discussion.
    Because there're still debatable arguments being presented, I guess :-)
  • »12.01.14 - 12:13
    Same debate, no real new arguments.
    I knew there was a reason I avoided that site!
  • »12.01.14 - 14:38
    If you avoid OS4-centric sites, you surely can't know what the "OS4 crowd" has or hasn't been talking about, can you? This renders any statement that you didn't see them talking about this or that completely pointless.
  • »12.01.14 - 14:58
    >If you avoid OS4-centric sites, you surely can't know what the "OS4 crowd" is or isn't talking about, can you? This renders any statement that you didn't see them talking about this or that completely pointless.
    I don't avoid ALL sites that discuss OS4.
    I still hang out on Amiga.org frequently (even if that can get painful).
    But the posters on AmigaWorld are just too confrontational (this coming from the very soul of contention).
  • »12.01.14 - 15:03
    > I don't avoid ALL sites that discuss OS4. I still hang out on Amiga.org frequently
    Visiting sites that also "discuss OS4" in passing isn't enough to see what the "OS4 crowd" is or isn't talking about. For this you need to visit OS4-centric sites like amigans.net and amigaworld.net.
  • »12.01.14 - 15:31
  • vox
    vox
    Cell is availiable, can be developed futher.
    We could play with PS3 and one day develop real innovative machine
    using main CPU all those programmable units. As far as I understand,
    its NOT just Altivec, one unit could do MUI, other Reggae and so on (or game AI, rendering, visual effects, screen dragging ...) cooperate with nVIDIA gfx or in some other system some RadeonHD.
    Needed drivers can be ported from Yellow Dog Linux.
    Even if its experimental MOS 4 Cell special edition with limited
    number of apps, GIMP, Blender and few Linux + some best AmigaOS 3/MorphOS apps
    could really demo a nice and multimedia usable HW/SW combo.
    As far as I understand Cell is smaller then G5 and some new board can be developed around it, as well as CPU itself is basis of supercomputer in chain, and alone as single Cell can be developed and scaled further. G5 and PA6T have reached its maximum and I am not that much impressed (yet) by X5000 CPU until proven wrong.
    Quick Google shown:
    http://www.psu.com/forums/showthread.php/18448-New-IBM-CELL-benchmark-may-2006-vs-G5
    PS3 CELL is About 30% less powerful than blade server(2 core less) : 35 time - 30%=24 time faster than the dual G5.
    So in theory PS3 should be 10 times better at 3d imaging and apps than the XB360. Even if I cut this in half it is still 5 times better.
    http://www.yellowdog-board.com/viewtopic.php?f=15&t=6537
    YDL is yet not well optimized, and Cell optimized MOS SE with some apps could be a real Cell showoff
    However - if you custom code for the Cell, it can do some things that are very hard to do with normal processors. In fact, the Cell resembles a graphic card GPU more than a regular CPU. For example, it can do vector mathematics quite well.
    It is true, I am using the Cell for scientific computation, Cell's performance depends on how much I can tame it, the creature is still wild to me.
    I would expect 2-digits performance over my office i7 by the end of this year though the YDLPS3 is my home computer and my boy's game machine.
    Cell's OS and Office suit performance does not bother me much, I thought YDL team had done some great low level job to optimize the OS code.
    I only worry about my next cell machine, can Fixstars sell the powerstation with a Cell processor rather than G5s? Or, even better, only sell Cell's motherboard (integrated even better, moderate GPU is OK), I just plug in with everything PC components
    Maybe its even possible to do Cell PCI or PCI-E card for Pegs and SAM460x :-) Even Efika :-)
    Cell alone can do much much more then most of CPUs
    http://en.wikipedia.org/wiki/IBM_Cell#Possible_applications
    [ Edited by vox 12.01.2014 - 17:53 ]
  • »12.01.14 - 15:43
    Posts: 2564 from 2003/2/24
    Cell might be neat in one way or theother, but in the field of personal computing it is just as much a dead end as PPC.
  • »12.01.14 - 16:12
    More so, they are still planning new additions to various PPC lines, the Cell is toast.
  • »12.01.14 - 18:20
    Posts: 2730 from 2003/2/24
    It's by far even more dead than PPC for desktop PC's. It was never meant to be a desktop CPU even back when it was new, it has poor performance by todays standards, and hasn't even the cell concept for parallel computing been made redundant and obsoleted by CUDA/OpenCL years ago already, and even more so on modern GPU's? Nobody is making new Cell HW, especially not desktop motherboards, and IBM even ditched the Cell development a few years ago. So I'd say it's even "deader than dead"!
  • »12.01.14 - 19:02
    > Cell [...] can be developed futher. [...] single Cell can be developed and scaled further.
    By whom?
    > We could one day develop real innovative machine using main CPU all those
    > programmable units.
    Who is "we"?
    I believe GUI classes are too intertwined with the actual program logic to allow for execution by something like Cell SPEs.
    The use of the SPEs from OtherOS is openly documented.
    Of course that would be possible, but who should do it and why?
    And it won't be optimized for Cell any better as Fixstars gave up on the Cell years ago. The last YDL version supporting Cell was 6.2 in 2009. Starting with 6.2.1 in 2010, YDL went x86+CUDA, so no PPC support at all. With 7.0 in 2012, YDL has switched back to PPC, but this time POWER7-only, no Cell nor any other PPC.
    There're already Cell PCIe cards. As for Cell PCI cards, who should make them?
  • »12.01.14 - 19:39
  • vox
    vox
    Kronos wrote:
    Hey mr moderator, you wanted to share some wisdom?
    Cell is dead end, XDR is bad, BlueRay is awful?
  • »13.01.14 - 05:21
    vox wrote:
    Cell is dead end
    It sure is. Especially so for desktop PC's.
    XDR is bad
    I'm sure it had its points, however I only see DDR3/GDDR5 today (even the new Mac Pro, which is a monster, spec wise), perhaps for a reason?
    BlueRay is awful?
    I suppose it's good for what it was meant to be, a next-gen dvd, but optical disks per se has become something of the past, or at least it's heading in that direction very rapidly. If I hadn't already been owning a DVDR unit that could be re-used from my old PC, I wouldn't have put one into the tower of the new PC I built. I hardly ever use it, and a portable one would have done just fine for those rare occasions, and it could be kept in a drawer the rest of the time. The only reason I ever used the bluray in my PS3 was because most game came in this way only. But they are slow, have fixed limits, gets damaged easily, you have to get your ass up from the sofa to change them, they cost money, they create pollution when being produced, and adds to the huge waste mountains when you discard them. Frankly, I don't se a lot of positive sides with bluray.
  • »13.01.14 - 10:13
    hooligan
    Posts: 1948 from 2003/2/23
    They said the same about cd's and dvd's, both selling today and will in the future, as will bluray.
  • »13.01.14 - 10:42
    Posts: 1090 from 2004/9/23
    Yeah, but noone uses them for computer purpose anymore. Whatever-drives often are an addon these days. I personally did not *burn* a media for quite some time, so I did not even notice my drive was broken for probably several years.
    They may still sell disc based media these days, but the use of home made discs is quite rare. It is easier to store the stuff on local drives and use them on all systems instead.
    Speaking about the topic. It has been said porting to a console won´t be happen. Also the PS3 is a quite bad target these days. The WiiU is more powerful, has the right 3 core cpu, 2GB of memory and other cool features like build in display, nfc, camera, mic, but it still will not happen, as it makes simply no sense.
    Even porting to the X1000 would make more sense than porting to a game console.
    Geit
  • »13.01.14 - 14:07
    hooligan
    @Geit
    Ok. How do you / did you install all the versions of MorphOS? I have always had to burn the damn disc.
  • »13.01.14 - 15:31
    Intuition
    Posts: 1116 from 2013/5/24
    hooligan wrote:
    @Geit
    I copied the boot.img from the mac_ppc32 folder to boot: then rebooted. Then I mounted the ISO and ran Tools/IWizard but Jaca told me this method is very bad and not supported.
    The other way is to make a 512MB FAT16 partition on a USB stick and copy the boot.img from the ISO along with the ISO image itself and boot it from open firmware.
    http://www.meta-morphos.org/faq.php?id_cat=11&myfaq=yes&categories=Mac+mini#32
    [ Edited by Intuition 13.01.2014 - 18:02 ]
  • »13.01.14 - 16:13
    hooligan wrote:
    @Geit
    MorphOS supports booting from ISO file for quite some time.
    Geit.
  • »13.01.14 - 16:44
    hooligan
    geit wrote:
    hooligan wrote:
    @Geit
    Geit.
    How? No such thing is mentioned in installation guide.
  • »13.01.14 - 17:26
    hooligan wrote:
    geit wrote:
    hooligan wrote:
    @Geit
    It is explained here for example. On Macs it basically works the same.
    Geit
    [ Edited by geit 13.01.2014 - 19:52 ]
  • »13.01.14 - 17:49
