Posts: 545 from 2015/6/18
Quote:Andreas_Wolf schrieb:
> I had not paid attention to the Wii U being PPC. [...] Can't find any reference
> if it got Altivec/VMX. Probably not as it seems to be PPC750 based.
Yes, see the large quote in comment #110
Xenon, the Xbox 360s CPU would be more powerful with it's 3-core (+ SMT)
> 3,2 GHz + VMX. The downside is the Xbox360 having only 512 MiB RAM...
...and the CPU cores just doing in-order execution, so you can't really do a simple comparison with out-of-order Espresso based on clock frequency.
Ah yes! Thanks for the hint.
So it's 3,2 GHz + Altivec In-order Xenon
vs. 1,24 GHz Out-of-order Espresso
vs. 0,35 - 1,67 GHz + Altivec Out-of-order G4 7400-7455
vs. 1,6 - 2,7 GHz + Altivec Out-of-order G5 970.
I guess the Wii U would at least be a perfect replacement/improvement of the G4 Mac Minis having more CPU power, more/faster RAM and a more capable GPU.
[ Editiert durch ernsteiswuerfel 29.06.2020 - 00:29 ]Talos II. [Gentoo Linux] | PMac G5 11,2. PMac G4 3,6. PBook G4 5,8. [MorphOS 3.18 / Gentoo Linux] | Vampire V4 SA [ApolloOS / Amiga OS 3.2.2]
