Posts: 1178 from 2003/3/13
Brumiga wrote:
The monitor is used at its native resolution 1920x1200 pixels
Pornographic resolution! That's 2.3 megapixels! I think "antialias" will be out of computer dictionaries very soon...
at 60 hz.
Of course, one has to get as close as possible to the frequency the monitor is able to "listen to" (usually 60 hz). Some accept wider margins, others are more picky. By the way, why I can't see SmartFirmware's 640 x 480 screen?
the display is smooth in digital mode.
Of course, I will buy the adapter soon (mi DVI cable says its "-D", for "digital", I guess). When using digital signals, do all those analog parameters in CyberGraphX disappear?
Finally I removed the vga cable because I do not have any other computer than my pegasos 2.
Which is something to celebrate!
