Important Notice regarding X5000 Firmware Updates
    redrumloa
    Posts: 1424 from 2003/4/13
    I read this thread with my jaw open while shaking my head in disbelief. Wow.
    Wow.
  • »30.10.20 - 15:25
    TrevorDick wrote:
    Mark,
    Not sure why you posted on a public forum but I can assure you that uboot firmware updates for the X5000 have not been circulated outside the ExecSG team.
    The excellent work you did for me on uboot helped the ExecSG team create a standard uboot build process. As I assured you at the time, I will ensure that any and all future uboot updates for the the X5000/20 and X5000/40 will support MorphOS. I have a vested interest since I run MorphOS on my X5000/20 :-)
    The ExecSG kernel work will not impact on MorphOS support.
    Trevor
    It's not really my place to step into the middle of this, but I just want to address this one question of Trevor's, with the most likely answer, that everyone has read in Mark's initial post to this thread. Mark/Bigfoot posted this here because Solie and to an extent Trevor himself kept refusing to give Mark the answers to his questions in those emails. I think if it had been me, I probably would have resisted helping the ExecSG team even more than Mark did, and I would not have given them the source code, until they DID answer my questions fully. But that is just my opinion on how I would have reacted, and Mark is a much more helpful and "Nice Guy".
    It seems completely reasonable to me for Mark to post this warning publicly, when he was kept "out of the loop" by Trevor and the ExecSG team, but learned what was going on and put the pieces together that seem to confirm his fears. I don't know if Mark made one last attempt to get the answers directly from Trevor or the ExecSG team, which I would have done before posting here, but it is done now, so why doesn't the ExecSG team and owner come out with an official statement to clear things up and ease the minds of the users. All of this "cloak and dagger" secrecy in our tiny community is silly. We are too small and way too far behind all other platforms to worry that anyone is going to steal the ideas of our development teams, and I can't see any benefit in keeping the users in the dark about what is going on. In fact, I think it hurts our community.
    After all the help that Mark has provided to get MorphOS working on the X5000, I hope that it won't all be in vain because A-Eon decides to drop support for MorphOS, due to the current graphics card problem between the two OSes, and the apparent low number of users running MorphOS on an X5000.
  • »30.10.20 - 17:17
    Posts: 2451 from 2003/2/24
    The moment you realize that running abandoned HW with no chance of any firmware updates is a blessing.....
  • »30.10.20 - 17:29
    Doffo
    Posts: 508 from 2010/10/14
    :D
    YUUUP!
  • »30.10.20 - 18:03
    Jupp3
    Posts: 1193 from 2003/2/24
    Regarding this "don't upgrade", is there something that prevents users from downgrading to previous version, if there are problems? (like firmware upgrades are done on modern games consoles, for example)
    Also, an average user will probably think it's better to add as much features as possible to the firmware. But is there actually any benefit in doing that, instead of "doing as little as possible", and handing the control to the OS as soon as possible? (I assume the answer is "absolutely none") - would the OS actually run exactly the same, if firmware was completely erased once the system was booted up?
    I think it's also good to point out that this firmware rom is mostly different from Amiga Kickstart ROMs. Both definitely do some initializations, but classic Amiga ROM (or ROM image in RAM) continues to play a significant role once the OS is up and running.
  • »01.11.20 - 11:39
  • ASiegel
    Posts: 1387 from 2003/2/15
    @Jupp3
    The issue at hand is that the possibility of downgrading your firmware version does not undo severe data loss that was caused by a prior upgrade, hence the need for a public warning before MorphOS users might be the victim of potentially irreversible damage.
  • »01.11.20 - 13:10
    Posts: 12408 from 2003/5/22
    > [...] classic Amiga ROM (or ROM image in RAM) continues to play
    This is because classic AmigaOS is actually two-part, disk-based and ROM-based, with the Amiga Kickstart ROM containing the ROM-based portion of the OS. The MorphOS equivalent of the Amiga Kickstart ROM is the boot.img, which is obviously not firmware, but OS. OS4 maintains a similar scheme.
  • »01.11.20 - 15:12
    amigakit wrote:
    A-EON Technology is not affiliated to the "ExecSG" team as Trevor has pointed out.
    The private branch of the firmware is used for testing and developing the ExecSG projects and has nothing to do with the consumer release of the firmware.
    The official X5000 firmware that is distributed on X5000 systems and board is the version that BigFoot has worked on for A-EON over some years.
    He is the official maintainer of the firmware for A-EON. A-EON is happy for this relationship to continue going forward and presumably BigFoot is too (his schedule permitting).
    And yet, the official maintainer of the firmware for the X5000 systems is asked for help in compiling or setting up an environment that can compile the source code, and is ignored and kept in the dark, regarding projects that modify the firmware he is supposed to be maintaining.
    WHY?
    [ Edited by amigadave 01.11.2020 - 08:54 ]
  • »01.11.20 - 15:51
    Debvgger
    Posts: 4 from 2017/7/13
    Wow. Talk about mistreating a developer. This is so wrong on so many levels.
  • »03.11.20 - 11:11
    I just watched ssolie's AmiWest 2022 talk on ExecSG, where he also mentions the need for a firmware update for the X5000 (and others) in order to make use of OS4 with multicore-enabled ExecSG currently under development. Summary as follows:
    "Solie is also responsible for firmware updates. The U-Boot versions for X5000 and A1222 plus not only received various bug fixes, but will now also correctly initialize the additional cores of the multi-core CPUs used in these machines. Firmware updates will be distributed "soon" via A-EON. Once they're installed, the respective computers will then be "multi-core ready"."
    http://www.amiga-news.de/en/news/AN-2022-10-00104-EN.html
    Does the opening posting of this thread still apply, now that it's 2 years later?
  • »27.10.22 - 09:45
    bigfoot
    Posts: 510 from 2003/4/11
    This is exactly what my initial post on this thread refers to, so yes, it very much still applies.
  • »27.10.22 - 10:11
    Thanks for the reply.
  • »27.10.22 - 17:46
    Posts: 891 from 2003/3/4
    From what I saw of Amiwest, some backbone functions are being added to support multicore OS4, but there's still no idea how it's going to work in praxis. Because we know how discussions on having multiple concurrently-working CPUs on an OS with a task-shared memory address space usually end up.
    Just the usual OS4 stuff, start designing the cushion covers for the house you're going to build, some day...
    So probably best to avoid these updates if you plan running MorphOS, unless they do something useful like power down the unused cores.
    [ Edited by KennyR 29.10.2022 - 17:05 ]
  • »29.10.22 - 14:03
    bigfoot
    Unfortunately not even that would be a good excuse. MorphOS already does power down the unused cores, and doing so doesn't actually require booting them and taking them over. You can do it entirely - and easily - from the boot core.
  • »30.10.22 - 04:57
    Very nice :-) Has this been the case since MorphOS 3.10 or been added later? I don't remember I already read this, at least looking through the release notes since 3.10 I cannot find anything with respect to this.
    Btw, has this feature also been added for PowerMac11 (PPC970MP) meanwhile? (I know that generation isn't officially supported, and that MorphOS supports this on PowerMac7 (PPC970/PPC970FX) since MorphOS 3.10).
  • »30.10.22 - 08:50
    bigfoot
    It's been this way since MorphOS 3.10
    Btw, has this feature also been added for PowerMac11 (PPC970MP) meanwhile? (I know that generation isn't officially support, and that MorphOS supports this on PowerMac7 (PPC970/PPC970FX)).
    I don't know, sorry :)
  • »30.10.22 - 09:27
    Posts: 1335 from 2004/2/8
    I can only hope the answer is 'no' as my QUAD consumes approximately 280W when idle.
    If that would be on just one CPU core that would be insane.
  • »12.01.23 - 09:54
    Posts: 545 from 2003/4/11
    Are you planning to win the morph.zone thread off-topic price of the day and did you check that without gfxcard ? :)
  • »12.01.23 - 10:01
    > 280W when idle. If that would be on just one CPU core that would be insane.
    Btw, regarding PowerMac7, there've been findings reported in another thread based on temperature sensor signal suggesting that the 2nd CPU is not completely disabled. So far, I've not seen any explanation what "Disabled the second CPU on PowerMac7 machines" really means technically.
  • »12.01.23 - 13:00
