A-EON AmigaOne X5000/20 works great with MorphOS!
    Posts: 12085 from 2003/5/22
    > we are limited to northern island and lower cards.
    It's more complicated than that because the actual GPU architectures, which are what determine (non-)support, don't correspond to the "Islands" family names (which correspond to the R(V)Xxx GPU names). The Northern Islands family (= RV9xx GPU) also contains such GPUs with TeraScale 3 architecture (i.e. HD69x0 cards with RV970 "Cayman" GPU) that isn't really supported by MorphOS.
    In conclusion, it would be more correct to say that MorphOS support is limited to most of Northern Islands (i.e. RV910 "Caicos" GPU to RV940 "Barts" GPU) and all lower GPUs.
  • »19.02.21 - 10:46
    Piru
    Posts: 576 from 2003/2/24
    Generally I think it is a better solution to get a setup that can run MorphOS right now than to wait for some support that may or may not arrive.
    Of course this is something that users with specific setups don't want to hear, and of course it is inconvenient if you can't have best of the both (or multiple) worlds easily in your system.
    We really need to focus on things that give most benefit for all users, not just some rather small subset of users of one particular system/setup. We also look at the registration numbers of specific models to see where the focus should be put. Before anyone asks, yes, we do understand that lacking driver support might not encourage registrations.
    Please don't read too much into this comment. It is not an official statement of any kind, just a friendly reminder that while some things would be great to have (from your point of view), it still might not happen anytime soon, if at all. You could be waiting for a very long time (if not forever).
  • »20.02.21 - 15:52
    walkero
    Posts: 102 from 2006/3/1
    Hello guys,
    I am trying to boot on my X5000/40 MorphOS using a USB, but it stacks after bootmorphos and doesn't load at all.
    The last printed messages are:
    Trying to load "bootcyrusplus.img" from "SDH0:"...
    Loaded "bootcyrusplus.img" from "SDH0:", booting...
    After that stays on uboot grey screen without proceeding.
    Tested 4 different sticks but no luck with any of them. I also tried with no hard disk plugged in.
    In case the Gfx cards I tried on my machine are not supported, would I see something after that step, for example black screen or grumbled graphics? I tested an HD770, R9 280X and a Gigabyte GV-R725XOC-2GI.
    Any recommendation?
  • »08.06.21 - 19:01
    Posts: 2998 from 2003/3/5
    Not sure what HD770 is but it does not sound like you have a supported graphics card.
  • »08.06.21 - 21:39
    walkero
    @jacadcaps
    Thank you so much for your reply. I will try to find a compatible card and proceed with that. Does anyone have any card to recommend as the best choice?
  • »09.06.21 - 16:50
    Just for MorphOS? Or do you want to run other operating systems also?
  • »09.06.21 - 19:41
    walkero
    @Andreas_Wolf
    Just for MorphOS...
  • »09.06.21 - 23:30
    > Just for MorphOS...
    Then it's the one mentioned there (or rather the one mentioned 5 comments later).
  • »10.06.21 - 00:18
    walkero
    Thank you so much Andreas. Will look for one of these cards. Probably for the X1950XT.
  • »10.06.21 - 00:23
    Primax
    Posts: 129 from 2021/7/2
    zukow schrieb:
    @Skateman
    The best card for X5000 with MorphOS is X1950XT. It supports 3d, overlay, 2d acceleration. it is quite cheap but powerfull. It is also supported by AmigaOs4.x although without 3d.
    I am currently trying to replace my Radeon HD5450 by the X1950 XT, at least for testing purpose because the card is too big for regular usage.
    The question: Do I have to manually change something in the options of MorphOS because after having booted the X5000, the Boing Ball appears, then the MOrphOS boot loader starts and then a black screen appears saying: Wrong screen resolution, set it to 1920x1080@60Hz.
    But I cannot do anything..
    Any hints?
    @walkero
    Have you already found and installed a XT? Any experiences?
    AmigaOne X5000 @ 2GHz / 4GB RAM / Radeon X1650 / AmigaOS 4.1 Final Edition / MorphOS 3.17
  • »26.07.21 - 05:10
    Posts: 20 from 2018/4/2
    I had the same issue when i ahve changed my GPU, the only way to solve is booting on the DVD and make a new install
    or maybe change manually the screen prefs afiter booting on the DVD.
    first try the boot on the dvd or the usb
    Regards
  • »30.07.21 - 13:40
    Primax
    @gordini21
    Thank you very much for the hint!
    Yes, I could boot with the help of the USB-Stick.
    But I do not know what to do then...
    Because: In Prefs/Screens the correct graphics card is set (X1650Pro).
    Do I have to copy this prefs? Is this X1650 configuration only saved for/on the USB-Stick?
    The only strange issue: In prefs/monitors a wrong monitor (31kHZ) is set. But also if I enter there the correct values of my monitor, save and then try to boot with the SSD disk, I get the 'wrong screen resolution' message....
  • »30.07.21 - 19:53
    Posts: 2033 from 2003/2/24
    Primax wrote:
    @gordini21
    It's good that it works when booted from the USB stick, then you can get it to work from the installed system too.
    Withouth thinking this too well now, I'd have couple quick suggestions. You could remove (or rename to different name to be revertable) the System:Prefs/Env-Archive/MUI/screens.txt file. This defines which resolution and monitor Ambient and other screens are trying to open. And if this doesn't help, try the same with the System:Prefs/Env-Archive/sys/PublicScreens.prefs file.
    I think that if these files are missing, MorphOS tries to use something that it finds for defaults and it should work as booted from the installation media. These are probably created only after user has manually saved some related settings...
    EDIT:
    And of course you could try to boot MorphOS into some default resolution instead to a saved one. Press the CTRL key during the startup to get it forced to the 1024x768@75Hz VESA mode, or press the Shift key or LMB to get into the early startup boot menu where you can select between some other modes.
    [ Edited by jPV 31.07.2021 - 10:42 ]
  • »31.07.21 - 08:28
    Primax
    @jPV
    Thank you very much!!
    Shift+LMB did not work. I guess because the wrong/correct screen resolution is loaded *before*.
    But: With some luck, CTRL key work.
    And I guess I have found the reason why I am having trouble: It is due to my monitor.
    Booting with CTRL key I got some standard screen, as you described. If I then set the sreent resolution to 1920x1080 - my Philips Brilliance 241B has 16:9 format - I immediately get the info: Wrong screen resolution. Set it to 1920x1080@60Hz. And the screen get black.
    Okay, I again did the procedure and had a closer look:
    For the X1650Pro I only can choose a 1920x1080@76Hz. Obviously my monitor cannot display that.
    Now I have changed to 1280x720@60Hz: And this does work - but of course is not that fun.
    Funny enough: If I am remembering correctly, for my HD5450 there also is only 1920x1080@76Hz available but the monitor can display it. Has anybody an explanation for that???
    Could this has anything to do with HDMI connection (HD5450) and DVI connection (all X-cards)??
    And is there any poosibility to add a screen resolution of 1920x1080@60Hz for the X-cards?
    Thank you!!!
  • »31.07.21 - 10:14
    > It is due to my monitor. […] is there any poosibility to add
    You could try this workaround. (Shot in the dark, though.)
  • »31.07.21 - 11:32
    Primax
    Thank you.
    But in this case - for once i found this out myself - it is much more simple:
    MorphOS does recognize my monitor: Philips Brilliance 241B. But obviously assigns a wrong freqeuncy of 75Hz.
    ---> System: Prefs/Preferences/Monitors
    Under monitor specifications my monitor is listed.
    Choosing '24Bit 1920 x 1080' under Screen resolutions and then 'Edit....'.
    And there a screen resolution of 1920 x 1080p (60hz) is available.
    Test....Working!
    Ok....Save....Restart.
    And yes, it works! :)
    I have only one question:
    What is the difference between '1920x1080p(60hz)', '1920x1080 (60hz)' and '1920x1080(60hz)CVRB2'?
  • »31.07.21 - 13:03
    Primax wrote:
    @jPV
    It was Shift or LMB, but not simultaneously.
    I guess there are different settings (pixel clock, sync and pulse values, etc) for same resolutions that are standards or common enough otherwise. For example, that last one seems to refer to this: https://en.wikipedia.org/wiki/Coordinated_Video_Timings.
    I guess you should just try which one works with your monitor if you don't know better :)
    EDIT: well...... I changed from 1920x1080p to 1920x1080 CVTRB2 myself.... less bandwidth, less load to gfx chip or something? :P
    For future references, it seemed to modify a monitor file in Prefs/Presets/Monitors/ directory. And you can see name of the monitor file from the Prefs/Env-Archive/CyberGraphX/RadeonMonitor file. If someone needs to play/fix/revert/debug these settings...
    [ Edited by jPV 31.07.2021 - 20:55 ]
  • »31.07.21 - 18:33
    xeno74
    Posts: 40 from 2020/6/8
    I am still very happy with MorphOS on my X5000. :-)
    Screenshot: https://i.ibb.co/yh5mb8S/Kernel5-17-rc1-Power-PC.png
  • »23.01.22 - 17:49
    xeno74
    Hi All,
    I was able to update to MorphOS 3.17 on my AmigaOne X5000/20 today. Many thanks for this great update! :-)
    Screenshot: Morph-OS-3-17.png
    A-EON AmigaOne X5000 Update Instructions
    Download SD Card / USB Image for X5000: morphos-3.17-hybrid.hdimg MD5SUM: A7211CD3BF4D939ACAA2EE8CF4B0095B
    You will need a 500MB or larger USB disk
    Prepare the USB Disk
    Copy the image to a USB disk
    Linux Instructions
    With your system powered on, insert a USB disk that is at least 500MB into a USB port
    Determine the /dev path to your USB disk using one of the below methods:
    - In a terminal as su or sudo, enter "fdisk -l"
    - In a terminal as su or sudo, enter "parted -l"
    - Check the GParted menu in the upper-right corner
    These instructions assume the /dev path to your USB disk is /dev/sdz; however, your actual /dev path is likely to be different - use the actual /dev path to your USB disk
    In a terminal as su or sudo, enter the below command:
    dd if=/path/to/morphos-3.17-hybrid.hdimg of=/dev/sdz
    where "/dev/sdz" is the /dev path to your USB disk
    NOTE: Do not attempt to copy the image to a specific partition - you need to enter the /dev path to the disk, not to a partition (use "/dev/sdz", not "/dev/sdz2")
    Mac Instructions
    Open the Terminal app in Applications > Utilities
    Determine the /dev path to your USB disk by entering the below command:
    diskutil list
    These instructions assume the /dev path to your USB disk is /dev/disk9; however, your actual /dev path is likely to be different - use the actual /dev path to your USB disk
    Enter the below command:
    dd if=/path/to/morphos-3.17-hybrid.hdimg of=/dev/disk9
    where "/dev/disk9" is the /dev path to your USB disk
    Windows Instructions
    With your system powered on, insert a USB disk that is at least 500MB into a USB port.
    Download "USB Image Tool" from alexpage.de
    Open USB Image Tool
    On the left panel, select your USB disk
    Click the "Restore" button and select the MorphOS disk image
    Boot to MorphOS
    Begin with your A-EON AmigaOne X5000 system powered down and insert the USB disk into a USB port - remove any other USB disks that are plugged in.
    Power on your system and press ESC when the boot animation starts to load the U-Boot menu.
    Choose "Command Line" from the U-Boot menu
    Type the following commands:
    usb reset
    bootmorphos
    After selecting the language and keymap please select "Installation ..."
    Choose "Update Installation"
    Choose the MorphOS volume and the button "Update".
    After that please shutdown MorphOS (Ambient - Shutdown... - Shutdown) and remove the MorphOS USB stick.
    Please start the AmigaOne X5000 and the new MorphOS 3.17 will boot automatically.
    Cheers,
    Christian
  • »14.05.22 - 13:25
