A-EON AmigaOne X5000/20 works great with MorphOS!
    dirkzwager
    Posts: 23 from 2016/10/21
    Looks great!!!!!
    That is a real dream computer.
    Do you run only Morph or dual boot Amiga os4.1?
    Powerbook G4 1.67 and 17", Morphos 3.13
    Power Mac G5 2.3 DP
    Sam 460 and AmigaOS 4.1 FE
    Amiga 4000/040 and The Picasso 4 ( yes the 4 )
    Amiga 500 plus
  • »02.07.20 - 04:12
    Posts: 440 from 2019/5/9
    xeno74 wrote:
    Hi All,
    My MorphOS computer is finished and works fantastic! :-)
    System:
    - A-EON AmigaOne X5000/20
    - ATi Radeon X1950 PRO Extreme
    - Creative Soundblaster LIVE Player 1024
    Cheers,
    Christian
    Hi Christian, nice to see you also on MorphOS side ! ;-)
    Marti
  • »02.07.20 - 04:32
    kas1e
    Posts: 97 from 2005/10/31
    @Xeno74
    On the screenshots, I can see that you have big Radeon in one slot and x1950 in another one, did it mean that dual-booting works for mos/os4? I mean, I want to have morphos install also on my x5k, but want to keep Polaris card for os4, so is it works if you just add "ATi Radeon X1950 PRO Extreme", and then both oses can work, just morphos one set up for x1950 and os4 one for Polaris?
  • »02.07.20 - 06:56
    Nice system!
  • »02.07.20 - 09:30
    Spectre660
    Posts: 276 from 2015/6/30
    @Kas1e
    The big thing is a cooler for the x1950.
    The x1950 configuration would triple boot Mos/OS4/Linux but no 3D under OS4.1 .
    (Be careful mentioning Polaris "roun ya")
    X5000 GPU thread.
    kas1e wrote:
    @Xeno74
    [ Edited by Spectre660 02.07.2020 - 14:04 ]
  • »02.07.20 - 14:58
    kas1e wrote:
    @Xeno74
    I only see one video card, and one sound card installed in his picture of the inside of his X5000, where are you seeing this other picture that shows 2 video cards installed?
    I'm assuming that the video card with the big AcceleratorX2 cooling fan on it is the Radeon X1950, not any other "big Radeon" video card, as you described, but maybe you are looking at some other picture that is not included in the three links in the original post in this thread?
  • »02.07.20 - 18:02
    Posts: 8 from 2013/7/24
    How does it run on the X5000/40?
  • »02.07.20 - 21:39
    Posts: 12452 from 2003/5/22
    > installed? [...] maybe you are looking at some other picture that
    What confuses me is that he said he saw this on "screenshots". The first of the three pictures is indeed a screenshot, but it shows info of only one installed graphics card.
  • »03.07.20 - 02:46
    kas1e
    @AmigaDave
    No no, I just mess that big cooler with RadeonHD/RX. That confused the last one who answer in the topic as well.
  • »03.07.20 - 07:41
    kas1e wrote:
    @AmigaDave
    Not an HD/RX, an R500 series Radeon X1950 PRO.
  • »03.07.20 - 16:23
    xeno74
    Posts: 40 from 2020/6/8
    Hi All,
    I have one graphics card installed. It's my MorphOS machine so I don't need another graphics card.
    Linux works also on this X5000. Screenshot: ec2315010d01bf86fccebc18550c28a2.png
    How can I use only my fonts in OWB? I would like that my OWB ignores the font settings from the web sites.
    Thanks,
    Christian
    [ Editiert durch xeno74 03.07.2020 - 22:02 ]
  • »03.07.20 - 18:01
    ...and the sound card with a graphics card :-)
    What got me confused foremost was the strange use of the term 'screenshot' :-)
  • »04.07.20 - 05:33
    TheMagicM
    Posts: 1220 from 2003/6/17
    thats awesome. Man..I havent used my G5 in I dont know how long...or my g4 laptop.
  • »21.07.20 - 11:01
    redrumloa
    Posts: 1424 from 2003/4/13
    You're missing out IMO. MorphOS is really great these days, especially with Chrysalis Pack!
    [ Edited by redrumloa 21.07.2020 - 11:17 ]
  • »21.07.20 - 13:17
    TheMagicM
    I'll power it up. I think its up-to-date with MorphOS. I'll check.
    Oops.. I'm on 3.12.
    [ Edited by TheMagicM 22.07.2020 - 22:10 ]
  • »23.07.20 - 01:06
    waldiamiga
    Posts: 96 from 2007/7/25
    P5040 runs a full G4 CPU emulation here (i.e. no KVM), right? Btw, QEMU can also emulate Rage 128 Pro instead of SM501/502.
    Yes, I think the Rage 128 works better than the SM502. Just type
    -device ati-vga,guest_hwcursor=true
    instead
    -device sm501
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »30.07.20 - 10:15
    xeno74
    Andreas_Wolf schrieb:
    > It runs also in a virtual QEMU machine:
    > https://i.pinimg.com/originals/ee/d5/b3/eed5b39df93d74f263fcb747859f533b.png
    Yes that's correct. I also tested it with KVM-PR on my X1000 but it doesn't boot with KVM-PR enabled. The emulation of the Rage 128 works only on my PC. On my AmigaOnes it has wrong colors and other issues. Maybe endian issues. I don't know. The emulation of MorphOS isn't important for me because it runs very well on my X5000/20.
  • »30.07.20 - 10:22
    xeno74
    MorphOS update instructions with a USB stick:
    Choose "Command Line" from the U-Boot menu
    Type the following commands:
    usb reset
    bootmorphos
    Screenshot of MorphOS 3.14 on my A-EON AmigaOne X5000/20: MorphOS314.png
  • »05.10.20 - 15:04
    Posts: 38 from 2020/10/11
    Looking good Christian,
    I would love to give MorphOS a try but with only one X5000 i would have to change my Videocard.
    I would be nice if based on the Radeon Driver sourcecode by Hans de Ruiter, a MorphOS driver for the AMD Radeon SI and RX cards would appear :-)
  • »13.10.20 - 07:21
    Posts: 1338 from 2004/2/8
    I believe some of the HD 7xxx and RX 200 series are supported already (albeit without hardware overlay and 3D support), as seen here.
  • »13.10.20 - 08:03
    ernsteiswuerfel
    Posts: 570 from 2015/6/17
    Don't think so as the hardware page states "R7 250, R7 260 and HD78x0 graphics cards are not supported." ;-)
    The other Rx or 7xxx cards listed on the page are no Polaris cards. AMD has the habit to re-label some old cards when a new series arises, e.g. a Radeon R5 230 is a relabeled HD6450 which is a minimally improved HD5450 itself. All 3 sharing the same chipset which is certainly not the same the other Radeon Rx cards (being Polaris).
  • »13.10.20 - 08:30
    I see some of the cards are already supported. I will check what chipset my R7 250 is using.
    Then again, 3D etc support would be very welcome.
  • »13.10.20 - 08:31
