How to run MorphOS on unsupported iMAC G5
    MoerBoer
    Posts: 237 from 2019/10/15
    Strange, I've never had issues with mine.
    The fans ramp up when needed and the temperature is properly controlled without any extra programs.
  • »12.10.20 - 07:21
    AKiLL
    Posts: 93 from 2006/3/6
    In my case, without manually adjusting fan speed via the iMacFanCtrl tool, after about half an hour of normal use (without major commitments for the CPU) the temperature systematically rises from 45°C (just after boot) to 78-85°C and the Northbrige controller also reaches beyond 90°C. In this situation, I do not hear the fans start automatically and I suppose that in such temperature conditions hardware damages would be almost inevitable.
    In your case, at what temperatures do the fans automatically increase?
    Probably Frank could clarify our doubts about the automatic adjustment of the fan speed to the temperature increase.
  • »12.10.20 - 12:13
    MoerBoer
    My fans ramp up drastically at about 85c cpu ( northbridge sits at about 72c at that stage )
    It sounds like a jet for a second or two then drops the cpu temps quickly to about 75c and it gradually goes down then.
    Normal usage for me it sits at about 65c - 70c for the CPU and 70c for the northbridge
  • »12.10.20 - 14:01
    BatteMan
    Posts: 288 from 2003/2/24
    If you want to do it automagically at every boot, you can add this in your user-startup :
    	C:talk2smu_setfan 0 2500 >NIL:
    C:talk2smu_setfan 1 2500 >NIL:
    C:talk2smu_setfan 2 2500 >NIL:
    You can modify 2500 by a number between 0 to 5000 (but 0 is maybe not a good idea ^^).
    /me doesn't put those lines in his startup but it's a good idea ^^
  • »12.10.20 - 17:41
    AKiLL
    Where did u find that talk2smu_setfan command ?
  • »12.10.20 - 19:17
    Posts: 545 from 2003/4/11
    This is no official tool, actually. I will probably release another update to the fancontrol UI tool that allows to define some minimum rpm values on startup.
  • »12.10.20 - 20:16
    Posts: 18 from 2017/10/7
    Thank you for your answers. Looks like it's safe to get one now :)
  • »14.10.20 - 12:36
    sabbate
    Posts: 110 from 2013/7/7
    i bought today an isight for 100 euro from a german dealer, in the past i used morphos but my machines had broken they were all g5
    Hello:)
  • »19.10.20 - 16:44
    MoerBoer
    Welcome! Maybe you are also lucky with your temps, like I've been. Mine rarely gets hot unless I run Encore demos non stop, but the fans does their thing
    qdqc2w2
  • »19.10.20 - 17:01
    sabbate
    yes fortunately i read how to fix the fans :), however wayfarer is one of the reasons why i got imac and i think i will support jadacaps
  • »19.10.20 - 17:26
    MoerBoer
    Mine is running fine without any fan issues or programs, hence hoping you might be also be lucky.
  • »20.10.20 - 04:02
    sabbate
    yes it is a refurbished imac, i have seen photos of its interior too, it should work without problems
  • »20.10.20 - 08:42
    There is a new version 0.4 of iMacFanCtrl available at morphos-storage.net which allows to adjust minimum rpm values and which can also be configured to skip the UI in order to avoid any additional user interaction on startup launch.
  • »01.01.21 - 15:16
    AKiLL
    Just downloaded and installed. Thanks for the update.
  • »01.01.21 - 17:10
    Posts: 2065 from 2003/6/4
    Frank, what's still stopping you from adding the iMac G5 to the official supported hardeware list? To my recognition none of the iMac users reported real issues. Except the fan thing which seems to affect only some users and can get fixed by the fan control program .
    I am pretty satisfied with my iMac G5. 3.15 runs fine on it.
    [ Editiert durch Zylesea 02.01.2021 - 01:12 ]
  • »01.01.21 - 23:08
    Fogg_80
    Posts: 45 from 2007/11/12
    You are right. My iMac have had fan problem, but with 3.14 all ok, I hope even with 3.15.
    Stile Ubuntu
    Sorry for my bad english.
  • »02.01.21 - 07:57
    Well, maybe for MorphOS 3.16. We typically don't add additional hardware support for bug-fix updates. The main reason iMac G5 isight isn't officially supported is that there are plenty of other iMac G5 variants that don't work at all to run MorphOS, so you basically are on your own to look one up that works.
    Speaking of smooth experience, starting with MorphOS 3.15, the released installation hdimg - dubbed #?hybrid.hdimg for this reason - can be booted via USB stick on various supported Apple hardware if you dump the raw image to some USB stick directly and modify the boot device in OF via
    setenv boot-device ud:,\\:tbxi
    If it can't find a related USB device, it should fall back to HD/CD boot automatically. It will take a while until it times out on iMac for example but rather useful if you quickly need to boot from a MorphOS live image and don't have a CD at hand or your CD drive is already starting to act up.
    We will provide some more detailed information about this new installation feature at some later point.
    If you are already using a more complex boot menu or modified the boot process otherwise, this is probably less appealing.
    Unfortunately, the USB stick won't show up in the graphics boot menu which would make it even simpler but it seems Apple decided not to support that early boot feature back then.
  • »02.01.21 - 12:41
    Flash
    Posts: 106 from 2019/11/1
    Hi Frank,
    What about G5 quad official support ?
    I have mine with pcie eth card (Realtek) and pcie Wi-Fi card (atheros) running okay from at least mos 3.13 release.
  • »02.01.21 - 14:49
    Posts: 2452 from 2003/2/24
    Flash wrote:
    Hi Frank,
    Since non of those can run MorphOS out of the box I doubt that ever to happen.
  • »02.01.21 - 14:58
    Posts: 12408 from 2003/5/22
    Isn't this the same as with eMac and PowerBook G4?
  • »02.01.21 - 15:39
    Divinity
    Posts: 498 from 2009/9/8
    is it possible to use the webcam and internal microphone in the iMac?
  • »02.01.21 - 21:23
    discreetfx
    Posts: 399 from 2003/7/26
    @Divinity
    Thanks for the question, I would love to know the answer to this too.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »26.01.21 - 19:38
    Posts: 826 from 2007/10/23
    @Divinity
    At least you need the firmware...
  • »29.01.21 - 17:37
    Kronos wrote:
    Flash wrote:
    Hi Frank,
    ? All I changed was my video card, and my quad is running MorphOS fine (I still need a network or wireless card). 8 GBs of memory (w/ >6 going to waste), but no problem leaving it all in place. I did have trouble trying to install a CMI based audio card and a SiI3132 PCI Express SATA controller card, but I'll try those again now that I have it running.
    Not enough expansion slots and they are too close together (wide video cards cover the nearby slot).
  • »29.01.21 - 20:27
    Posts: 19 from 2021/1/31
    Hi there, why does the G5-20" work and the G5-17" 1,9Ghz (x600pro) not?
    What hardware is the problem on the 17" model? Thx
  • »03.02.21 - 14:43
