How to run MorphOS on unsupported iMAC G5
    Posts: 12085 from 2003/5/22
    > Elastic Interface ( Apple schematics terminology )
    In fact, Elastic Interface is a term coined by IBM and adopted by Apple.
    > U4 [...] = CP925 [...] = Kodiak
    Seems the confusion still prevails:
    CPC925 = U3/U3H
    CPC945 = U4 = Kodiak
  • »19.05.22 - 12:39
    Posts: 358 from 2019/5/9
    @Andreas
    corrected. Too much too similar numbers.
    AmigaOS4: Micro A1-C, AmigaOne XE, Pegasos II, Sam440ep, Sam440ep-flex, AmigaOneX1000
    MorphOS: Efika 5200b, Pegasos I, Pegasos II, Powerbook G4, Mac Mini, iMac G5, Powermac G5 Quad
  • »20.05.22 - 07:21
    And if I study our iMac G5 iSight Schematics, there is another interesting findings:
    iMac use SATA connected HDD and ATA connected DVD.
    But in real, used Southbridge have two SATA ports, and only one is connected.
    If anybody wants (and he finds appropriate pins on motherboard) I have the scheme how to connect it. It needs four additional condensers, but it is not too complex.
    Then you can connect or modern SATA optical drive, or second SATA HDD (with both disks 2.5" size to fit to one 3.5" bay).
    Of course, it is only HW point of view. I am not sure if OpenFirmware or OS recognized device which was not taken into account.
    Southbridge is Broadcom, type (yet) unknown, but can be ( at least partially ) identified by PCItool, device ID. Apple codename is SHASTA. But for SATA port addition no identification is needed.
  • »20.05.22 - 07:40
    NewSense
    Posts: 1478 from 2012/11/10
    I've been using my iMac A1145 for a while now, and for some reason I never noticed, until now, that there doesn't seem to be a brightness option, as far as I can tell, for it in preferences to reduce or increase that feature of the screen itself, or does someone know how to adjust the screen brightness on these iMacs? :-?
    There is of course a keyboard control for the PowerBooks, and other notebook type hardware. For the MacMini you need a separate screen that usually has some independant way to adjust the screens brightness but with the iMac there doesn't seem to be this feature supported, as yet, is this an oversight, or a problem in working out just how Apple got it to function with Mac OSX, and make it work within MorphOS? :-?
  • »15.08.22 - 02:29
    Posts: 2242 from 2003/2/24
    The API for that exists and I do have a primitive 20% ready screenbar module that uses it.
    Maybe I‘ll do the next 75% once I get the new PastePass out of the door.
    If I look at what my boss thinks about the use of my time that may end up being in the year 2525……
  • »15.08.22 - 05:24
    Posts: 2992 from 2003/3/5
    I’ll be bringing some of the PowerBook services to the iMac support for 3.18…
  • »15.08.22 - 12:14
    MoerBoer
    Posts: 212 from 2019/10/15
    Very cool!
    Any idea how hard it is to get a bootscreen going for there?
  • »15.08.22 - 18:32
    Posts: 4 from 2020/10/13
    Just hit a brick wall on trying to update my G5 iMac iSight 20" to 3.17 (currently running 3.16). I'm trying to boot from USB (can't from the optical as it is non-functional), but after the 'quiescence' message I'm getting the following error:
    Invalid memory access %SRR0: 00000000.00c02230 %SRR1:100000000.00003030
    I've tried re-downloading the iso in case it was a download error, but hit he same problem. Any help would be much appreciated!
    Thanks,
    Nigel.
  • »15.08.22 - 18:53
    bigfoot
    Posts: 508 from 2003/4/11
    You're probably booting the wrong boot image. You need use the boot image from the mac_ppc64 directory, not the mac_ppc32 directory.
  • »15.08.22 - 19:10
    Ah, user error, might have known! Many thanks, I'll give that a try,
    Cheers
    Nigel.
  • »15.08.22 - 19:46
    Posts: 780 from 2007/10/23
    Indeed, an architecture check at the beginning would be helpful. Maybe at OFW level somehow?
    [ Editiert durch polluks 16.08.2022 - 17:48 ]
  • »16.08.22 - 16:45
