How to run MorphOS on unsupported G5 PCIe
    zukow
    Posts: 657 from 2005/2/9
    and also frequency handling
    What does this refer to?
    Ahh, it wasn't added to Release notes as different line - so R500 had problems with some of Monitors (including my 24" Dell), lower resolutions weren't available - they gave - 'Out of sync' on the monitor. There is much better now.
    > 5-years-old AmigaOS4.1FE
    FE Update 1 is 3 years old :-)
    Right, with one main feature - better memory support for Classic - very important for X5000 user. I was refering to the fact that MorphOS Team doesn't support X5000 well which isn't true. Did Hyperion provide network driver for X5000 lan? MorphOS Team provided.
    > OWB in MorphOS will be updated
    Without engine update this will help only so much.
    MophOS Team did fixes also in the engine - CSS flexbox is working so sites such as http://allegro.pl looks ok and as more and more sites will use flexbox - more pages will look garbage on AmigaOS4.x.
  • »16.10.19 - 15:34
    zukow wrote:
    ..... as more and more sites will use flexbox - more pages will look garbage on AmigaOS4.x.
    Yeah, the updates from Hyperion are all way too little in substance, and way, way too long in waiting for them to arrive, but pointing these things out to OS4 users does not improve their opinion of MorphOS, so it is better to just ignore what is (isn't) happening at Hyperion, and instead just point out what great things are happening on MorphOS.
    If it weren't for the developer team that is funded by A-Eon & AmigaKit, that is producing consistent updates for OS4 users, we would hear a lot more complaining from those OS4 users, and maybe some of them would see the light and switch to MorphOS. Unfortunately, some of them will never consider using MorphOS, mostly because of some past very bad exchanges between the two groups of users on forum sites. People would never be so rude to each other face to face, but the illusion of being untouchable when typing stuff on a forum site makes some people (not you) write stupid and hateful things, on both sides.
  • »16.10.19 - 16:54
    Posts: 12542 from 2003/5/22
    > available - they gave - 'Out of sync' on the monitor There is much better now.
    Thanks for info.
    The general news and fixes that are also relevant for X5000 users don't read too shabby for such a minor release, I think :-)
    Besides Bigfoot's driver provided by A-Eon for OS4, there is another Cyrus/X5000 Ethernet driver for OS4 done by Jamie Krueger to be provided by Hyperion. I don't know if this driver has been delivered beyond beta testers yet.
  • »16.10.19 - 17:13
    Posts: 902 from 2003/3/4
    Kronos wrote:
    redrumloa wrote:
    using newer gfx cards on OS4.1 gives you no added value.
    You should be able to run 4k res with some of the Radeons supported by the pay-extra drivers.
    Without GUI scaling though, 4k is a really bad idea for anyone who doesn't have a huge 4k monitor.
    So back to no added value.
  • »16.10.19 - 17:50
    redrumloa
    Posts: 1424 from 2003/4/13
    Looks like I may get a chance to try out your unsupport very soon :-D
  • »22.10.19 - 01:45
    zukow
    Added another tested Radeons to the google gallery (link in 1st post)
  • »26.10.19 - 18:49
    Posts: 1354 from 2004/2/8
    What are these? Some 2400s?
  • »27.10.19 - 06:57
    EDIT: I've found that the second one is Asus Radeon HD3450. I guess no 3D here.
  • »27.10.19 - 07:01
    zukow
    yes, radeon model number are added as comments there
    no 3d and overlay doesnt work correctly in 1080p
  • »27.10.19 - 07:12
    Posts: 3 from 2019/11/6
    Hi all. I've always been curious about MorphOS and when I heard that it un-supports Powermac11,2 now... so I bit. I've had one of these G5 macs laying around for years. I bought one of the Sapphire X1950XT "boobs" cards from ebay, flashed it for PPC and shockingly it worked. Installed MorphOS and it all seems to work besides some bootup problems due to a past FreeBSD installation.
    But I know very little about AmigaOS and even less about MorphOS. If I get one of these cards is this the right card to get? And if so will the network device just appear or do I have install one of the .device drivers? I don't see any of those anywhere on the installation disk.
    https://www.ebay.com/itm/PCIe-10-100-1000M-GLAN-realtek-RTL8168E/274047265184
    Thank you!
  • »06.11.19 - 12:50
    Posts: 2217 from 2003/2/24
    It should just appear in the network preferences, no manual installation needed. The drivers are there in MorphOS/Devs/Networks directory, so you just didn't look deep enough ;) But as said, they are already in use and no need to touch anything. Files in the MorphOS directory aren't meant for users to mess around, so keep your hands out of it.
    As you're a new user (welcome!), I'd suggest you'd read articles in the MorphOS Library. Getting Started could be useful, for instance.
    I'm not a hardware expert, but would look good for me. I just bought the one Zukow recommended, but as this also seems to have the supported chipset, I can't see why it wouldn't work.
  • »06.11.19 - 13:15
    Thanks I see now that the card he has pictured is an RTL8111 but I can't tell what the letter is after it. I looked for a specific model to be posted and I didn't find it. The RTL8111E on ebay does indeed seem cheaper. I'd like to just not waste my time and get something that I know someone else has working.
  • »06.11.19 - 16:46
    CraigE
    Posts: 23 from 2017/5/28
    I recently managed to install MorphOS on my Quad G5 using a X1900XT and this exact network card, from this exact listing, so I can confirm this one 100% works: amazon link
  • »09.11.19 - 13:17
  • ASiegel
    Posts: 1397 from 2003/2/15
    @ CraigE
    Thanks for sharing.
  • »09.11.19 - 13:33
    RTL8111E from ebay for $9USD works great!
  • »10.11.19 - 23:17
    zukow
    IMPORTANT!!! (or in fact VERY IMPORTANT :) )
    Please register your morphos G5 PCIe machine. We need to know how many users can use G5 machines to add more support for that (for very low registration numbers. adding network drivers will have low priority). Paying is not necessary, just use RegTool and send info about your devices.
  • »11.11.19 - 08:30
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Anyone tried running Linux on a PCIe G5 with a flashed ATI Radeon 1900 XT? I am curious if you actually get to the desktop with such a card. Be it with or without HW acceleration..
  • »12.11.19 - 13:45
    zukow
    I have two PCIe G5s for internal testing and in the 2nd one i have flashed X1950XT and it works without serious problems (although a bit different than X1950XT with PC Bios). I used older version of AtiFlash and some rom for Mac Radeon X1900GT. Flashing from PowerMacG5 PCIe itself isnt supported.
  • »13.11.19 - 06:56
    ernsteiswuerfel
    @zukow:
    Thanks for the hint! I guess if I am able to flash a X1900 GT/XT running the G5 11,2 with MorphOS/Linux/MacOS is less cumbersome than with 2 cards.
    I only found this X1900 GT Mac-BIOS on MacElite (klick). Did you use this one? As far as I've seen the Mac X1900 GT has 256 MiB RAM. Would be interesting to know if you can flash this BIOS to a 512 MiB card and it does still work? If so, there would be quite a range of X1900 cards suitable!
    Flashing on a PC is not a big problem with PCIe cards. Probably flashrom (on Linux) works too and you don't even need Windows/ATIflash.
  • »13.11.19 - 09:52
    zukow
    I had mac OF rom from somethere (probably from here:http://themacelite.wikidot.com/wikidownloads2), i don't have any original Mac PCIe Radeon. Windows version of Atiflash didn't work but Dos version worked from USB.
  • »13.11.19 - 10:01
    Doffo
    Posts: 508 from 2010/10/14
    Thanks Piku from trying out if a Realtek 8111E card works.
    YUUUP!
  • »19.11.19 - 21:54
    ernsteiswuerfel
    Thanks! Now got my Radeon X1900 XT which looks like one of the cards of the compatibility list pictures. Then I realized I still need to get this special LogicBoard->PCIe power cable. Which isn't a standard PCIe power cable, isn't it? What a surprise. ;-)
  • »21.11.19 - 15:17
    Doffo
    Bought me an x1900 xt which I noticed in the picture had the aux power cable for the video card all for $14 shipped. :) Came in today. Will get to try MorphOS this evening. No ethernet, but I will grab a handful of files and put them on a USB memory stick for now.
    YUUUP!
  • »21.11.19 - 17:20
    Posts: 141 from 2017/8/6
    I tested the mentioned card this morning; it is unsupported yet, it seems.
    it is right between
    X1900GT
    ~> X1900XT <~
    X1950XT.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=12146&post_id=143678&viewmode=flat&sortorder=0&showonepost=1
    [ Edited by amifrog 21.11.2019 - 20:08 ]
  • »21.11.19 - 18:06
    Doffo
    it is right between
    X1900GT
    ~> X1900XT <~
    X1950XT.
    Oh no! :( Which version is your x1900xt? Mine is a Sapphire x1900 XT 512MB. PC one of course... Just to be sure, did you try the 2nd DVI port on the card?
    YUUUP!
  • »21.11.19 - 18:42
