Pegasos 2 HDD/SSD SATA options
    Posts: 838 from 2007/10/23
    @sailor
    That sounds interesting, what graphics cards would you like to test?
    I suppose for Matrox Parhelia we have no drivers...
    [ Editiert durch polluks 05.04.2023 - 12:51 ]
  • »05.04.23 - 08:40
    Posts: 450 from 2019/5/9
    @polluks:
    Matrox Parhelia is nice card, but most probably not more powerful than Radeon 9800 PRO, which is now in my Pegasos 2. Not count the drivers ;-).
    But there are PCI HD cards - one of them (HD4350) works for me in 33 MHz PCI slot.
    - when bigfoot finishes new gfx drivers, these cards could be faster than 9800 PRO.
    Largest profit can be from testing PCIe cards. Like X1950 or HD Northern Islands. Maybe they will not works because of Smart firmware initialization behind the PCI-PCIe bridge - we will see.
    And second what could work very nice here is SiI SATA1 or Promise SATA2 cards. Promise SATA2 I tested some years before ( see first post ) and speed was limited by slow PCI 33 MHz slot.
    [ Edited by sailor 05.04.2023 - 15:18 ]
  • »05.04.23 - 11:07
    Posts: 12465 from 2003/5/22
    > PCI slot. [...] Largest profit can be from testing PCIe cards. Like X1950
    Wouldn't this be the same as with your PCI HD4350 where SmartFirmware doesn't work but MorphOS does? After all, it shouldn't matter whether the bridge is soldered on the graphics card itself or on an adapter the graphics card is installed to.
  • »05.04.23 - 17:55
    Posts: 570 from 2003/4/11
    I doubt that an AGP to PCI to PCIe adapter will get you anywhere with a Pegasos2 speedwise. AFAIR, the Pegasos2 only gives you a PCI 66MHz slot with an AGP connector, that means that non of the additional AGP DMA transfers really work which are important to get any of the more recent (AGP) cards up to speed - if graphics acceleration works at all without proper DMA, that is ...
    Even if you can get any newer card to work somehow, don't expect that you reach any better performance from it which makes the whole setup kind of pointless IMHO.
  • »05.04.23 - 18:58
    cyfm wrote:
    ...which makes the whole setup kind of pointless IMHO.
    And this is exactly thing what should be tested.
    Look here - you have to translate from Czech language. Sam440ep-flex is now much better computer with PCIe R9 270X.
    Sam440ep-flex is similar case like Pegasos2 - AMCC440ep has only PCI controller ( this time with PCI connector ), exactly as Marvell Discovery 2 in Pegasos 2 ( that one with AGP connector ). Both controllers has 66 MHz.
    Moreover - Sam shares 66 MHz PCI bus with SATA driver and bridge with slow devices. Pegasos 2 has 66 MHz bus dedicated for gfx, with own Hostbridge.
    If you take a look on article above, you see that bus speed ( write to VRAM ) with PCI-PCIe bridge is much slower ( latency from pcie reverse bridge ) than classic PCI/AGP cards. Despite this disadvantage, pcie cards are better.
    Such thing cannot be exactly theoretically calculated - they should be tested in real conditions. And of course, it also much depends on drivers - PCIe cards are much more powerfull, but drivers should utilize them.
    Thus I am looking forward to bigfoot's great work.
    [ Edited by sailor 06.04.2023 - 08:36 ]
  • »06.04.23 - 04:25
    It will be great. if yes. ;-) I agree with you that it should be this way.
    But we will see - PCI HD4350 has incorporated PCI-PCIe bridge 8111 ( or 8112 ) on card. It works.
    If I tested these times another real PCIe card ( I forgot the type) with external bridge 8111, it not worked.
    So chance there is, we will see.
    [ Edited by sailor 06.04.2023 - 09:21 ]
  • »06.04.23 - 05:20
