MOS 3.10 Sam460 Radeon HD 6570 ?
    Spectre660
    Posts: 276 from 2015/6/30
    @Jim
    Just pointing out that an issue with HD6570's has been there since 2 years ago.
    My only compatible card now then would be a HD6450 as my 6670's died .
  • »27.03.18 - 19:36
    Posts: 14 from 2013/9/27
    >> Maybe I should go out and buy Radeon R5 230
    > That was the card Bigfoot recommended to Acill before last Fall's Amiwest demo.
    ...and it is the card he's just recommended in the MorphOS 3.10 news article thread, as well as the HD6450.
    Hi all
    Now bought a RadeonR5 230 this morning.
    * R5 230 works with Sam460 + MOS 3.10 CD via VGA output..Only available mode is 1920x1080
    * HDMI output gives a corrupted view..
    * Both VGA and HDMI output of Radeon R5 230 works with AmigaOS4
    Currently installing MOS3.1 on Sam460..Harddisk is conntected to PCI-E Sii3132 SATA card..
  • »28.03.18 - 07:44
    Spectre660
    @eightwonder
    I don't think that you can boot a Sam460 from the PCI-E Sii3132 SATA card.
  • »28.03.18 - 08:34
    Spectre660 wrote:
    @eightwonder
    Yes I connected harddisk to sii3114 afterwards.
    Btw DVI - HDMI is also working with R5 230.
    I tried Tower57 but it crashes other things work fine.
  • »28.03.18 - 10:56
    Posts: 12408 from 2003/5/22
    Yes, while the game content itself is software-rendered, it uses TinyGL to scale the game's rather small resolution to the resolution of the currently used screenmode. TinyGL only supports Radeon R200 to R500 GPUs, i.e. Radeon 8500 to X1950 cards.
  • »28.03.18 - 11:06
    bigfoot
    Posts: 510 from 2003/4/11
    Thanks for the input, everyone. I'll look into it and get it fixed ASAP.
  • »29.03.18 - 17:40
    bigfoot
    Also let me add that if your booting is stuck at the firmware screen as was reported earlier in this thread, then please try to wait 60 seconds and see if it continues booting. I've been informed that a bug managed to sneak into the final 3.10 release which might cause such a delay on booting for some people.
  • »30.03.18 - 05:36
    Hi Bigfoot
    I waited like 240 seconds with RadenHD 6570, but it doesn't boot..
    Back to R5 230 :)
  • »30.03.18 - 08:43
    eightwonder wrote:
    Hi Bigfoot
    Back to R5 230 :)
    Again, has anyone tried a higher end 6000 series card?
    Mark has his 6870 working, and I'm fond of the 6750 (it's still low cost and performs MUCH better than the 6570).
    Also, any word on how the 4000s look with overlay support?
    I'm bidding on an HD4890 and an HD6870 right now.
  • »30.03.18 - 13:30
    > has anyone tried a higher end 6000 series card? [...] I'm fond of the 6750
    See Acill's comment in the MorphOS 3.10 release article thread.
  • »30.03.18 - 16:34
    bigfoot
    For those of you with HDMI/DVI trouble, please give https://bigfoot.morphos-team.net/test/Radeon (md5sum: c454a3be7c82faf62451d4ddbc4d8862) a try.
    Download the file and copy it to mossys:Devs/Monitors - make sure it overwrites the original Radeon file, as having two different Radeon monitor files present won't work. Also double check that the file has the executable file protection bit set after downloading/copying, and finally make sure you have installation media ready in case it doesn't work right.
  • »31.03.18 - 04:24
    Spectre660
    @Bigfoot
    Thank you.
    EDIT: HD6570 DVI still has the problem.
    HD6570 HDMI works.
    Unfortunately I still have the issue with the Sam460ex onboard ethernet not connecting.
    [ Edited by Spectre660 31.03.2018 - 14:04 ]
  • »31.03.18 - 10:18
    Spectre660
    Also GfxSpeed seems to be crashing.
  • »31.03.18 - 12:09
    HDMI and DVI works both on R5-230
    Thank you...
  • »31.03.18 - 14:34
    bigfoot
    What's the connector configuration on that card of yours? Specifically does it have a dedicated VGA connector, or does it have a DVI-I port, with both digital and analogue signals?
    You'll have to be a bit more specific on that one. Crashes how?
  • »01.04.18 - 10:35
    Spectre660
    @Bigfoot
    The Card has a dual link DVI-I connector and a HDMI connector .
    Edit: seems that the DVI-I is recognized as Single link under AmigaOS 4.1
    GfxSpeed runs and at some point while it is running the screen goes blank and I cant get any display.
    [ Edited by Spectre660 01.04.2018 - 10:24 ]
  • »01.04.18 - 10:49
    Spectre660
    HD6570
    *: Object: ID: 310C name: HDMI_TYPE_A type: 3 id: C
    *: Object: ID: 3101 name: SINGLE_LINK_DVI_I type: 3 id: 1
    *: CONNECTOR TABLE:
    *: Connector[0] HDMI 1:
    *: Type: RHD_CONNECTOR_HDMI_A
    *: DDC bus: RHD I2C line 2
    *: HPD: RHD_HPD_3 (monitor not connected)
    *: Outputs:
    *: Output AtomOutputUniphyE:
    *: Type: RHD_OUTPUT_UNIPHYE
    *: Device Type: atomDFP1
    *: Device Record: Type: atomDFP1, Connector Type: RHD_CONNECTOR_HDMI_A,
    ConnectorID: 0xC, EncoderID: 0x21
    *: Connector[1] DVI-I 1:
    *: Type: RHD_CONNECTOR_DVI_SINGLE
    *: DDC bus: RHD I2C line 3
    *: HPD: RHD_HPD_0 (monitor connected)
    *: Outputs:
    *: Output AtomOutputUniphyC:
    *: Type: RHD_OUTPUT_UNIPHYC
    *: Device Type: atomDFP2
    *: Device Record: Type: atomDFP2, Connector Type: RHD_CONNECTOR_DVI_SINGLE,
    ConnectorID: 0x1, EncoderID: 0x20
    *: Output AtomOutputDACA:
    *: Type: RHD_OUTPUT_DACA
    *: Device Type: atomCRT1
    *: Device Record: Type: atomCRT1, Connector Type: RHD_CONNECTOR_DVI_SINGLE,
    ConnectorID: 0x1, EncoderID: 0x15
    : RadeonHD card successfully opened
    0000: 00 FF FF FF FF FF FF 00 22 F0 8E 28 01 01 01 01 ........"..(....
    0010: 11 15 01 03 80 33 1D 78 2E EE 95 A3 54 4C 99 26 .....3.x....TL.&
    0020: 0F 50 54 A1 08 00 81 C0 81 40 81 80 95 00 A9 40 .PT......@.....@
    0030: B3 00 D1 C0 01 01 02 3A 80 18 71 38 2D 40 58 2C .......:..q8-@X,
    0040: 45 00 FE 1F 11 00 00 1E 00 00 00 FD 00 32 4C 18 E............2L.
    0050: 5E 11 00 0A 20 20 20 20 20 20 00 00 00 FC 00 48 ^..............H
    0060: 50 20 32 33 31 30 0A 20 20 20 20 20 00 00 00 FF P.2310..........
    0070: 00 33 43 51 31 31 37 30 46 4A 35 0A 20 20 00 65 .3CQ1170FJ5....e
    0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
  • »01.04.18 - 11:07
    Spectre660
    HD6450
    *: Object: ID: 3113 name: DISPLAYPORT type: 3 id: 13
    *: Object: ID: 3102 name: DUAL_LINK_DVI_I type: 3 id: 2
    *: CONNECTOR TABLE:
    *: Connector[0] DisplayPort 1:
    *: Type: RHD_CONNECTOR_DP
    *: HPD: RHD_HPD_1 (monitor not connected)
    *: Outputs:
    *: Output AtomOutputUniphyD:
    *: Type: RHD_OUTPUT_UNIPHYD
    *: Device Record: Type: atomDFP1, Connector Type: RHD_CONNECTOR_DP,
    ConnectorID: 0x13, EncoderID: 0x20
    *: HPD: RHD_HPD_3 (monitor connected)
    *: Outputs:
    *: Output AtomOutputUniphyA:
    *: Type: RHD_OUTPUT_UNIPHYA
    *: Device Record: Type: atomDFP2, Connector Type: RHD_CONNECTOR_DVI,
    ConnectorID: 0x2, EncoderID: 0x1E
    *: Device Record: Type: atomCRT1, Connector Type: RHD_CONNECTOR_DVI,
    ConnectorID: 0x2, EncoderID: 0x15
    *: RadeonHD card successfully opened
  • »01.04.18 - 11:21
    Mozzerfan
    Posts: 100 from 2016/10/5
    Spectre660 wrote:
    @Bigfoot
    Thank you.
    HD6570 HDMI works.
    Onboard ethernet only works for me when I use DHCP. It doesn't work with a static IP.
    With Os4 I can use a static IP, so I know it's not a wrong setting on my system.
    I forgot to report this bug when I installed morphos 3.9.
  • »01.04.18 - 12:07
    bigfoot
    Spectre660 wrote:
    The Card has a dual link DVI-I connector and a HDMI connector.
    Could you please try to redownload https://bigfoot.morphos-team.net/test/Radeon and see if that makes a difference for your DVI connection? md5sum of the updated file is 98a9dca09f8ac346031c9fe48d9200ce
  • »02.04.18 - 16:02
    Spectre660
    @bigfoot
    Thank You.
    That fixes the issue.
    Both DVI and HDMI working with my Radeon HD6570.
  • »02.04.18 - 18:38
    Posts: 826 from 2007/10/23
    bigfoot our hero!
  • »02.04.18 - 20:28
    Spectre660
    @bigfoot
    GfxSpeed has an issue around Benchmark 13/260 on My Sam460ex.
    Screen just goes blank. Both Radeon HD6450 and Radeon HD6570.
    X5000 passes 13/260 with no problem.
    Also still have the network issue with the Sam460ex onboard network.
    Verified that it is not a general network problem as my X5000/020 with pciex1 RTL 8168 connects ok on the same network.
    My Sam460ex is one from probably the last batch produced.
  • »05.04.18 - 20:52
    Spectre660
    Just spotted an interesting difference under AmigaOS 4.1 between the Sam460ex and X5000/020 Memcopy performance with HD6550 and HD6570. DMA vs no DMA .
    Sam460ex - HD6450
    MemCopy Score: 603.20
    Operation MiB/s
    Copy to VRAM 301.07
    Write Pixel Array 626.69
    Copy from VRAM 57.86
    Read Pixel Array 57.92
    X5000/020 - HD6450
    MemCopy Score: 308.74
    Operation MiB/s
    Copy to VRAM 270.00
    Write Pixel Array 269.71
    Copy from VRAM 40.21
    Read Pixel Array 38.54
    With an R7-250x
    Sam460ex - R7-250x
    MemCopy Score: 602.57
    Operation MiB/s
    Copy to VRAM 305.42
    Write Pixel Array 629.77
    Copy from VRAM 53.19
    Read Pixel Array 54.13
    X5000/020 - R7-250x
    MemCopy Score: 584.04
    Operation MiB/s
    Copy to VRAM 532.90
    Write Pixel Array 530.81
    Copy from VRAM 54.10
    Read Pixel Array 52.25
  • »06.04.18 - 09:37
    Interesting, the biggest impact is on the HD6450.
    I never would have predicted the SAM460 as the winner in this contest.
    If you can, could you give us comparative benches under MorphOS 3.10?
    Edit - Sorry, that was a pretty stupid suggestion. We don't have a 3D driver for the first card, and there is no MorphOS drivers for the second (yet).
    The comparisons under OS4 still remain interesting. Shows the impact DMA has.
    [ Edited by Jim 06.04.2018 - 22:47 ]
  • »07.04.18 - 00:12
