G5 Dual/Quad core - how much would it take...?
    Posts: 12408 from 2003/5/22
    > It's being said one is encouraged to register the machine even without
    > paying immediately; but how does this work without network?
    With a supported Ethernet card :-)
  • »16.11.19 - 10:39
    Posts: 141 from 2017/8/6
    Ah, thanx. Ordered on the spot, will certainly arrive on time.:)
  • »16.11.19 - 10:55
    I just set everything up, installed the RadeonX1900XT and the NIC cards, and they seem to work fine with OSX (The NIC has no driver but is recognized at boot with a green link, and shows in System Profiler).
    Unfortunatly, when i try to boot MorphOS3.12 it seems to load files from the CD but the only thing i see is a white screen. I have both outputs connected, but only one works, as i said, showing a white screen....
    Any suggestion where to look at?
    Pics
    e3brjn55_png.htm xbench
    nt26b6zz_png.htm sprofiler
    57yghmem_png.htm driver inst.
  • »21.11.19 - 10:34
    Posts: 1335 from 2004/2/8
    Is your Radeon from the compatibility list?
  • »21.11.19 - 11:10
    I'm not sure. It's a Radeon X1900XT/256MB.
  • »21.11.19 - 11:17
