Now problems with the USB drives
    Templario
    Posts: 556 from 2012/4/28
    Already I got install the MorphOS 3.0 but when I plug a pendrive(where I have the keyfile) MorphOS only shows me the popup with the message that it recognizes the drive but it isn't show in the Ambient Desktop also I tested with other USB mass storage and neither when with MorphOS 2.7 these drives rans perfectly.
  • »09.06.12 - 15:26
    Posts: 3311 from 2003/3/5
    As always with USB problems, start by reading the Poseidon documentation (HELP:english/Poseidon.guide) and checking out its preferences.
  • »09.06.12 - 15:31
    Templario
    With MOS 2.7 I hadn't this problem!
  • »09.06.12 - 15:34
    Posts: 1521 from 2003/2/24
    Not even when you view drives (double click on the desktop) ?
  • »09.06.12 - 16:38
    Templario
    Poseidon recognize my pendrive, but clinking in the desktop isn't show the drive, neither with Multiview to see in modo file, the pendrive is showed, why Poseidon recognize it but doesn't appear in the desktop?
  • »10.06.12 - 07:33
    Korni
    Posts: 473 from 2006/2/23
    Remove ENVARC:sys/poseidon.prefs, reboot and try again. If this doesn't help, run Mounter and check if you can mount your usb partitions by hand.
    [ Edited by Korni 10.06.2012 - 13:31 ]
  • »10.06.12 - 10:30
    ausPPC
    Posts: 543 from 2007/8/6
    I have MorphOS installed on my 5.6 powerbook and there does seem to be an issue with automounting of flash drives. One of them will automount the 2nd time it's plugged in while another can be mounted manually with Tools/Mounter
  • »10.06.12 - 10:31
    Templario
    It didn't work, in fact now I have installated MorphOS 2.7 again, I delete the Poseidon Prefs, but the mouse and keyboard were death, to install to MorphOS 2.7 with it the USB drives works fine.
  • »11.06.12 - 11:27
    Posts: 10 from 2005/8/28
    Hi, same here!!!
    Mounter show correct the usb drive but not allow to mount.
    Only dismount option is posibble  :-(
    I check another pendrive and worked, i think the difference is FAT16 and not mounted is a FAT32 one i can see in the mounter info.
    Hope this help to find the problem.  :-?
    Ciaooo
    Jose A.
    [ Edited by QuarX 11.06.2012 - 23:33 ]
  • »11.06.12 - 20:14
    Templario
    The big question is why ins MorphOS 2.7 works fine and 3.0 not, what changed? and why to worst?
  • »12.06.12 - 12:48
    I not can say, if my 2.7 mount this pendrive OK.
    The only i remenber i have not problem at all with pendrives in 2.7 and now, i get this issue in the FIRST pendrive i use under 3.0. This is true.
    Ciaooo
  • »12.06.12 - 16:46
    eastone
    Posts: 47 from 2007/8/4
    I had the same problem with my Kingston DataTravet 4GB but i formatted it under MorphOS 3.0 and it works well now. Under MorphOS 2.7 i didn't have that problem.
  • »13.06.12 - 08:13
