Best MorphOS system?
    stephen_robinson
    Posts: 746 from 2007/4/22
    I've got a Dual 1.42 MDD, and a 1.5Ghz Macmini, I use the macmini more as it's
    a: Much quieter
    b: The performance is good enough with MorphOS, with MacOSX the Dual processor PowerbookMac leaves it standing..
    [ Edited by stephen_robinson 23.05.2012 - 15:10 ]
  • »23.05.12 - 04:52
    Posts: 12537 from 2003/5/22
    > will it be able to play 3D games like quake 2 and return to castle
    > Wolfenstein or will the lack of 3d acceleration be an issue?
    Naturally, the lack of 3D acceleration will be a very big issue for 3D games.
    > Essentially I want it to be even better than what i experienced on
    > my Pegasos 2 !!!
    For this you don't need the "best MorphOS system" by far ;-)
  • »23.05.12 - 05:22
    Fairdinkem
    Posts: 42 from 2010/8/20
    stephen_robinson,
    The performance is good enough with MorphOS, with MacOSX the Dual processor Powerbook leaves it standing..
    Sorry I can't quite make out what you are saying.... The powerbook leaves what standing?
    [ Edited by Fairdinkem 23.05.2012 - 17:23 ]
  • »23.05.12 - 05:22
    analogkid
    Posts: 719 from 2004/11/3
    @Fairdinkem
    "Power" is a matter of definition, IMHO. For me, expandiblity belongs to a powerful (main desktop) machine, too. The Mac mini and the Powerbook are powerful machines, without a question. For me, the EFIKA is a powerful machine, too, just a matter of expectations and purposes.
    [ Edited by analogkid 23.05.2012 - 07:25 ]
  • »23.05.12 - 05:23
    Fairdinkem
    Andreas_Wolf,
    Is the lack of 3D acceleration a software thing (ie they have not ported all drivers yet) or is it a hardware (or the lack there of) issue?
  • »23.05.12 - 05:26
    > issue?
    It's a software issue. 3D support for Radeon R300 GPUs is supposed to come in a MorphOS release after 3.0, not necessarily 3.1 though.
  • »23.05.12 - 05:29
    Fairdinkem
    Andreas_Wolf,
    So when this happens a powerbook could potentially blow the doors off a MDD?
  • »23.05.12 - 05:32
    > off a MDD?
    Probably not. Once 3D support for R300 GPU has been implemented in MorphOS, you'll be able to use such a card for 3D also in an MDD PowerMac of course.
  • »23.05.12 - 05:36
  • »23.05.12 - 05:39
    Fairdinkem
    Andreas_Wolf,
    So is that your recommendation  :-D
    What R300 GPU's are available that would be compatible with a MDD Powermac?
  • »23.05.12 - 07:55
    No, more like stephen_robinson's ;-)
    > a MDD Powermac?
    http://guides.macrumors.com/Radeon#R300_Core
    So that would be Radeon 9700 (Pro) and 9800 (Pro/XT) cards for the PowerMac G4. The 96x0 (XT) cards from the PowerMac G5 will probably work in the MDDs too.
  • »23.05.12 - 08:11
    stephen_robinson
    Fairdinkem,
    In the context of comparing a Macmini and a Powermac:-
    Using MacOSX, the single processor and the limit of 1GB of Ram means the Macmini is a bit underpowered for Leopard.
  • »23.05.12 - 13:07
    Fairdinkem,
    I can easily recommend a re-flashed ATI 9800XT PC video card.
    Mine was able to use the standard Mac rom file and operates at normal XT speeds.
  • »23.05.12 - 14:55
    Fairdinkem
    Is this model going to be compatible or is only the 17" model compatible?
    PowerBook G4/1.67Ghz 15in SuperDrive Aluminium A1106 M9677
  • »24.05.12 - 08:21
    > compatible?
    Yes, this is going to be compatible.
  • »24.05.12 - 08:33
    sacc-user
    Posts: 43 from 2012/5/2
    After AmigaDave showed morphOS at amiwest2011 and since I had the same laptop. I really wanted that option.
    Because ver3 hasn't been release I borrowed my kids mac mini, but she wanted it back for I just found a mdd fw800 1.42 dp.
    It was fun for one week, then the power supply died...
    Now I say, these ten yr old systems too much trouble
    any advice on BEST way to proceed?
    M
  • »27.05.12 - 23:10
    The power supply on my FW800 went bad about a week after I received it.
    That's not a problem limited to just these Powrmacs.
    I've lost count of the number of PC power supplies I've replaced.
    I was able to locate an ACBell replacement on Ebay fairly easily.
    Either the 360 or the 400 watt power supply works fine.
    I haven't had a problem since.
    And they're fairly easy to install (although slightly harder then the average PC power supply).
    If I were you, I'd just replace the power supply. If you're not interested in doing that, I'd be willing to bet there's more then one person here that would be willing to buy the system from you.
  • »27.05.12 - 23:59
    sacc-user
    I'll keep this in mind if the cost of this old system over runs my budget.
  • »28.05.12 - 00:37
    Well, one thing you're going to find is that FW800 power supplies are over priced, but I don't regret getting one (although I paid about half the going rate).
  • »28.05.12 - 00:51
    sacc-user
    Well, I recd a refurbished power supply.
    Just before MorphOS ver.3 was released. (sigh)
    Everything seems to be working both under mac10.4 and NOW morph3.
    I will finally get to use morph on my mac powerbook, which was my goal.
    So the FW800 will sit for a while.
    M
  • »12.06.12 - 15:53
