Ram on Pegasos II
    Posts: 7 from 2003/12/7
    I just installed a new RAM module of 512 MB in my Pegasos II, But when starting the machine, at the openfirmware banner I see only 128 MB but I don't know if this is the amount of RAM or not.
    Is there a way to verify the recognized amount of RAM ? through openfirmware or through morphos ?
    Thanks for your help !
    Zoddzodd
  • »01.01.04 - 16:35
    marcik
    Posts: 268 from 2003/4/12
    Type "avail" in shell.
  • »01.01.04 - 16:50
    Posts: 2732 from 2003/2/24
    You mean the top line of the openfirmware screen? I believe that line gives information about your graphics card, like model and the amount of RAM it has.
  • »01.01.04 - 20:20
    zacman
    Posts: 86 from 2003/2/26
    That's the ram of the graphics card you
    have ;-)
    In MorphOS there is the "avail" command
    to check for memory. Also a memtest utility
    is included to check if your RAM works
    without any problems.
  • »01.01.04 - 22:13
    Wishmaster
    Posts: 342 from 2003/6/29
    With glasses this wouldn't have happened, hahaa.
    Pegasos PPC
  • »02.01.04 - 12:35
    Thanks guys for all your replies !
  • »03.01.04 - 14:52
