Voodoo 4500
    Is anyone using a Voodoo 4500 video card?
    AGP or PCI?
    How does it compare to other options?
    Also, can a Powermac support a 3.3V video card (or does it require a 1.5v card)?
    [ Edited by Jim 09.01.2012 - 19:44 ]
  • »09.01.12 - 18:18
    vulture
    Posts: 198 from 2008/2/4
    used it for a while when I still had my peg1. Not a bad option, it's just it lags a bit when 1920x1080 is on compared to the Radeon. You'll also want to disable double/triple buffering as it only has 32mb of vram.
  • »09.01.12 - 18:41
    Thanks.
    As I like to experiment, I was considering re-flashing a PC 4500 AGP card with a Mac BIOS and giving it a try.
  • »09.01.12 - 18:49
    Posts: 12537 from 2003/5/22
    According to the PowerMac information boot_wb has gathered, PowerMac3,1 to 3,5 use 3.3 V whereas PowerMac3,6 uses 1.5 V.
  • »09.01.12 - 19:55
    Thanks Andreas,
    It is interesting that he quotes the 3,6 AGP slot as 66Mhz (as that would only be 2X speed - the speed earlier Powermacs operate at).
  • »10.01.12 - 09:41
    > 66Mhz [...] would only be 2X speed
    No, AGP is always running at 66 MHz, no matter if x1 or x8 speed. It all depends on the "pumping".
    http://en.wikipedia.org/wiki/Accelerated_Graphics_Port#Versions
  • »10.01.12 - 22:33
