External Firewire Hard Drive Enclosure
    XDelusion
    Posts: 602 from 2010/10/27
    So I hear that I can install OS X on an external Fire Wire HD and boot from it on my eMac.
    Now I am wondering if can buy any external firewire HD enclosure and use it for this purpose, or do only certain brands work?
  • »17.02.11 - 23:51
    Yomgui
    Posts: 348 from 2004/8/31
    Mac's hardware with FW connections have a minimal SBP2 driver in the firmware. So they can mount FW devices using this protocol.
    You can also put a Mac with FW in target mode, and uses its internal HD by FW, to boot or just access data from another computer.
    [ Edited by Yomgui on 2011/2/18 9:28 ]
    And now... next project!
  • »18.02.11 - 06:23
    JohnFante
    Posts: 163 from 2006/9/4
    How is that done more precisely?
    I have a Lacie firewire HD placed under my MacMini. I would like to try CruxPPC or something on it. http://cruxppc.org/
  • »18.02.11 - 06:36
    XDelusion
    So any enclosure should work then?
  • »18.02.11 - 06:42
    XDelusion
    I decided to give it a go with this:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200357960798&ssPageName=STRK:MEWNX:IT
    If it don't work, I'll just sell it or use it with my PC.
    John: To dual boot you need to hold down certain keys during boot time. Though, I forget what keys they were off hand as I've not done this in a couple of weeks, but that's the secret, you can get in and configure your Mac to do all sorts of things, including not play the token Apple boot up sound.
  • »18.02.11 - 08:41
    Yomgui
    @XDelusion:
    1394 norm defines only SBP2 as a sort of mass-storage (in fact it's a SCSI cmd over FW protocol).
    99.9999% of bridge chipsets use this norm, so any enclosure should work.
    But as always, norms are never understood or/and strictly followed: so some chipsets don't work well with Helios for example, like some oxford series.
    But MacOS-X handles them very well ;-)
  • »18.02.11 - 08:59
    Posts: 2090 from 2003/6/4
    Should work. I use some 2 1/2" iomega fw drive to boot OS X. I think that is the most convenient way for a dual boot system when OS X is used only rarely. No annoying boot menu, just plug in the firewire before you power on/reset if you want to boot OS X.
    Performance of a fw drive as system drive is good enough.
  • »18.02.11 - 11:07
    Posts: 1932 from 2003/10/19
    To boot into target disk mode in OS X you hold the "T" key at bootup. This turns any mac into an external firewire drive basicly, if your using 10.5 you can boot a USB 2.0 drive as well as a firewire drive. The drive needs to formated as a bootable device in disk utility and you hold the option key down during boot up. You will get a boot menu that will list the devices you can boot from at that point and simple use the mouse to click the one you want to boot off of.
    [ Edited by Acill on 2011/2/18 11:04 ]
  • »18.02.11 - 17:03
    I'm not sure I'm following this correctly.
    I think I might be confused by "To boot into target disk mode in OS X you hold the "T" key at bootup. This turns any mac into an external firewire drive basicly".
    Does this allow a Mac to boot from an external drive or does it "turn(s) any mac into an external firewire drive"?
  • »18.02.11 - 19:18
    Piru
    Posts: 617 from 2003/2/24
    Booting from FW can be done using the usual boot menu (alt key).
    [ Edited by Piru on 2011/2/19 2:33 ]
  • »18.02.11 - 22:33
    Thanks Piru.
  • »18.02.11 - 23:04
    XDelusion
    So how bad is the performance hit if booting from Firewire? Would I be ahead just to partion my internal drive and install OS X on it along side MorphOS?
  • »18.02.11 - 23:12
    Piru
    With firewire 400 it's upto 49MB/s, and firewire 800 upto 96MB/s. With FW800 it's mostly limited by the drive speed (I typically get 70MB/s from normal HDDs).
    FW400: slightly slower but not much
    FW800: Should be pretty much identical to internal HDD speed
    [ Edited by Piru on 2011/2/19 21:23 ]
  • »19.02.11 - 17:22
    XDelusion
    Aghhh.... well now I wish I'd have gotten an 800. Oh well, it's only OS X, I'm sure I won't be using it much if at all. In fact I'm not even sure why I want to install it? Oh ya...
    Jedi Outcast!!!! Damn I wish Lucas Arts/Raven Soft would open source that puppy so we could possibly have a port. :(
  • »20.02.11 - 02:58
    Piru
    eMac has FW400 only anyway.
  • »20.02.11 - 07:38
    XDelusion
    Oh, well great then!!! :)
  • »21.02.11 - 01:48
