[Poll] graphic tablet owners
    Yomgui
    Posts: 348 from 2004/8/31
    Hello,
    I want to make a poll to know the number of graphic tablet owners, all brands included.
    I want to know also if you use it under MorphOS.
    If you're one of them, please reply to this post.
    My config: Intuos 3 A5 Wide, Special edition.
    Thanks,
    Yomgui
    Current results
    Total owners: 13
    Per brands:
    Wacom: 8
    Trust: 2
    Tevion: 1
    e3Works: 1
    Unknown: 1
    I'm adding also results from MetaMorphOS
    [ Edited by Yomgui on 2011/1/7 9:11 ]
    And now... next project!
  • »05.01.11 - 11:07
    gleng
    Posts: 38 from 2006/10/15
    I have a WACOM Graphire 4. It works well under MorphOS as a pointing device, but I don't really know what art software would be best to use with it.
  • »05.01.11 - 11:19
    Tcheko
    Posts: 544 from 2003/2/25
    I do.
    wacom intus a3 usb. gd 12-12 U.
    It works straight without any poseidon tweaks.
  • »05.01.11 - 12:48
    Posts: 1361 from 2004/2/8
    Trust TB-1100.
    Works with minor Poseidon tweaks (needs correction of workspace size, as Poseidon assumes it's 12k*12k).
  • »05.01.11 - 13:16
    Yomgui
    @tcheko: 12-12U ???
    [ Edited by Yomgui on 2011/1/5 17:31 ]
  • »05.01.11 - 14:30
    Tcheko
    Yomgui wrote:
    @tcheko: 12-12U ???
    That's the model number on the product sticker.
    GD-1212-U to be precise.
  • »05.01.11 - 15:04
    cha05e90
    Posts: 58 from 2010/6/23
    I use an ancient but reliable serial.device connected Wacom tablet, type KT-04-05-R00. :-)
    II/G4
  • »05.01.11 - 15:54
    Yomgui
    @cha05e90:
    interesting! and Does it work well on morphos? Do you have pressure information?
    [ Edited by Yomgui on 2011/1/5 19:17 ]
  • »05.01.11 - 16:17
    bash64
    Posts: 977 from 2010/10/28
    I have the Intuos 4 (the humongous one).
    I have yet to try it out.
  • »06.01.11 - 00:30
    stefkos
    Posts: 102 from 2004/2/4
    I have one too, dont remember name:) im at work now:)
  • »06.01.11 - 08:12
    cha05e90
    I use A. Schwingl's Wacom commodity here with MorphOS - which works with i.e. fxPaint and the like. AFAIK my Wacom doesn't show "pressure" information with that driver (it's "greyed out"). So I suppose it doesn't support pressure. Funnily enough TVPaint's inbuild driver works with this tablet with my 68k Amigas, but refuses to work with MorphOS (or AmigaOS4.x). Don't know why.
    BTW: When I try to use this tablet with Gribouillis2 (running Wacom commodity) I can start to draw a line and then:
    Traceback (most recent call last):
    File "main.py", line 127, in <module>
    be_app.run()
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/app.py", line 119, in run
    File "Libs/pymui/_core.py", line 1051, in Run
    _muimaster.mainloop(self)
    File "Libs/pymui/_core.py", line 542, in convertor
    return func(self, msg._setup(tp.from_value))
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/docviewer.py", line 159, in MCC_HandleEvent
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/docviewer.py", line 428, in on_mouse_motion
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/docviewer.py", line 324, in _draw_on_motion
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/docviewer.py", line 115, in draw_stroke
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/docviewer.py", line 109, in paint_user_area
    File "OShare:Dummy/Test/Gribouillis2/view/pymui/docviewer.py", line 194, in _mcc_Draw
    File "OShare:Dummy/Test/Gribouillis2/view/backend_cairo.py", line 85, in init_cairo_context
    OverflowError: long int too large to convert to int
    II/G4
  • »06.01.11 - 08:48
    Sprocki
    Posts: 131 from 2005/2/23
    Tevion MD 9310
    I could not get it to work due to error messages about serial connection with Poseidon/FormAldiHyd. Would be fine to make use of it.
  • »06.01.11 - 11:18
    Jambalah
    Posts: 820 from 2008/3/30
    Trust TB-2100.
    Strangely, it worked flawlessy and now no more (workspace reduced): trying to set with Poseidon takes to "Application meditating" or freezes Pegasos. Sometimes disconnecting and reconnecting helps..
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »06.01.11 - 11:30
    realstar
    Posts: 298 from 2003/2/24
    I use an e3Works Stylo graphic tablet (5"x4"). It has always worked well with the standard HID driver. I mainly use it with TVPaint.
  • »06.01.11 - 11:35
    _bigdan_
    Posts: 70 from 2009/1/7
    Wacom Graphire 4 (Classic XL version)
    Used rarely under MorphOS 2.x (TVPaint, FxPaint..), mainly on MacOS X
    Hum, it would be useful under Pagestream... i'll try it soon.
  • »06.01.11 - 23:27
    SoundSquare
    Posts: 1214 from 2004/12/1
    Wacom Intuos 4 XL, never bothered to use it under MorphOS though.
  • »08.01.11 - 15:56
