CPU / MEMTEST
    Ruud
    Posts: 335 from 2009/2/2
    Allocated memory at 0x28172880 -> 0x5C9508BF, 880664640 bytes
    Writing and Verifying 0x00000000... Write 816 MB/sec. Verify 388 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 818 MB/sec. Verify 388 MB/sec.
    Memory is ok!
    System: PowerMac10,2
    Machine: 0x1
    PageSize: 4096 Bytes
    CPUCount: 1
    CPU0: 7447A (G4) Version 32771 Revision 258
    CPU0: CPUClock 1833333326 BusClock 166005898
    CPU0: FPU Unit exists
    CPU0: Altivec Unit exists
    CPU0: Performance Monitor Unit exists
    CPU0: DataStream Unit exists
    CPU0: ReservationSize 32
    CPU0: Ticks 4
    CPU0: CacheL1Type 0x0
    CPU0: CacheL1Flags 0x1000F
    CPU0: ICacheL1Size 32768
    CPU0: ICacheL1Lines 1024
    CPU0: ICacheL1LineSize 32
    CPU0: DCacheL1Size 32768
    CPU0: DCacheL1Lines 1024
    CPU0: DCacheL1LineSize 32
    CPU0: CacheL2Type 0x0
    CPU0: CacheL2Flags 0x1001D
    CPU0: ICacheL2Size 524288
    CPU0: ICacheL2Lines 0
    CPU0: ICacheL2LineSize 0
    CPU0: DCacheL2Size 524288
    CPU0: DCacheL2Lines 0
    CPU0: DCacheL2LineSize 0
  • »24.11.10 - 16:33
    Retested Powermac Quicksilver after installing 1.8Ghz Sonnett Processor
    Ram Disk:> cpu
    System: PowerMac3,5
    Machine: 0x1
    CPUCount: 1
    CPU0: 7445/7455 (G4) Version 32769 Revision 0
    CPU0: CPUClock 1799999995 BusClock 133160004
    CPU0: Ticks 4
    CPU0: ICacheL2Size 262144
    CPU0: DCacheL2Size 262144
    Ram Disk:> memtest disable
    Allocated memory at 0x2F89C1C0 -> 0x3DA45ABF, 236624128 bytes
    Write 568 MB/sec. Verify 387 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 570 MB/sec. Verify 387 MB/sec.
    Memory is ok!
    Interesting, check out the processor listed in the test and the fact that the memory benchmarks have greatly improved.
    [ Edited by Jim on 2010/12/17 0:37 ]
    [ Edited by Jim on 2010/12/17 0:58 ]
  • »16.12.10 - 22:34
    Posts: 12557 from 2003/5/22
    The wrong processor being reported seems to be a common problem:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7560&forum=11&post_id=79287#79287
  • »17.12.10 - 08:25
    Ruud
    I recently got hold of a complete Quicksilver 2002 system with a 7448 installed for a reasonable price:
    System: PowerMac3,5
    Machine: 0x1
    CPUCount: 1
    CPU0: 7448 (G4) Version 32772 Revision 514
    CPU0: CPUClock 1999999995 BusClock 133160004
    CPU0: Ticks 4
    CPU0: ICacheL1Size 16384
    CPU0: ICacheL1Lines 512
    CPU0: DCacheL1Size 16384
    CPU0: DCacheL1Lines 512
    CPU0: ICacheL2Size 1048576
    CPU0: DCacheL2Size 1048576
    Allocated memory at 0x2CB04B40 -> 0x5C9137BF, 803269760 bytes
    Write 308 MB/sec. Verify 381 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 308 MB/sec. Verify 381 MB/sec.
    Memory is ok!
    Very dissapointing memtest results with this cpu. I've tried different ram but that made no difference. A consequence of 7448 support being experimental perhaps?
    [ Edited by Ruud on 2010/12/20 20:15 ]
  • »20.12.10 - 18:15
    Jambalah
    Posts: 820 from 2008/3/30
    That's my test with a logic board I've recently purchased (MDD with one 1.25 ghz cpu):
    System: PowerMac3,6
    Machine: 0x1
    CPUCount: 1
    CPU0: 7445/7455 (G4) Version 32769 Revision 771
    CPU0: CPUClock 1249999995 BusClock 166636859
    CPU0: Ticks 4
    CPU0: CacheL3Type 0x0
    CPU0: CacheL3Flags 0x1001D
    CPU0: ICacheL3Size 1048576
    CPU0: ICacheL3Lines 0
    CPU0: ICacheL3LineSize 0
    CPU0: DCacheL3Size 1048576
    CPU0: DCacheL3Lines 0
    CPU0: DCacheL3LineSize 0
    Allocated memory at 0x2543BBC0 -> 0x4CC3DEFF, 662709056 bytes
    Write 731 MB/sec. Verify 380 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 734 MB/sec. Verify 380 MB/sec.
    Memory is ok!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »20.12.10 - 18:44
    Wow, you're the first MorphOS user I'm aware of reporting using a 7448, and the first one who reports running at 2.0 GHz. And to top that, it's both together. Nice :-D
    Could you please run the dnetc benchmark and report your results in that other thread? Thanks in advance. (Looking at your avatar I guess you might have done so already ;-)
    Yes, I'd be expecting rather something like Jim's results, if not better.
  • »20.12.10 - 22:49
    1/9th fasterv cloock speed and a more effiecient processor. If I had my choice (between the 1.8 7447 and a 2.0 7448) I'd choice the later.
    Strange memtest resuls.
    Quicksilver's are never going to match DDR euipped MDDs, but there's something odd going on there.
  • »21.12.10 - 01:18
    I think with this benchmark specifically it's more about the 25% faster FSB with most MDD models, less about the fact that MDDs use DDR SDRAM instead of SDR SDRAM.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6910&forum=11&post_id=71009#71009
  • »21.12.10 - 07:26
    Ruud
    I haven't run any benchmarks so far but I will soon. I've been too busy trying to work out how to reduce the noise output of this beast ;)
    I've tried the same ram in another Quicksilver with a Sonnet 1.8Ghz and got similar results to Jim. However I've also tested (yet) another Quicksilver with a Giga Designs dual 7447 1.8Ghz and got results much the same as I got from the NewerTech Maxpower 7448 2GHz equipped Quicksilver 2002 I posted above. So I'm puzzled.
  • »21.12.10 - 12:23
    Simon
    Posts: 809 from 2008/7/6
    well support for 7448 is called experimental ... maybe that's the reason ? And if you trough this topic, there other combinations giving disappointing results.
  • »21.12.10 - 16:45
    Frankly, considering the memtests I'm currently getting, I couldn't care less.
    [ Edited by Jim on 2010/12/21 20:45 ]
  • »21.12.10 - 18:38
    MorphDelf
    Posts: 274 from 2004/2/20
    Hi... MacMini 1.5GHz here:
    cpu
    System: PowerMac10,1
    Machine: 0x1
    CPUCount: 1
    CPU0: 7447A (G4) Version 32771 Revision 257
    CPU0: CPUClock 749999997 BusClock 166567207
    CPU0: Ticks 4
    memtest
    Allocated memory at 0x3ABBD7C0 -> 0x5CAD253F, 569462144 bytes
    Writing 0x00000000... 606 MB/sec.
    Verifying 0x00000000... 322 MB/sec.
    Writing 0xFFFFFFFF... 654 MB/sec.
    Verifying 0xFFFFFFFF... 327 MB/sec.
    Memory is ok!
  • »22.12.10 - 18:15
    Golem
    Posts: 766 from 2003/2/28
    Well that doesn't look right... so this is an overclocked 1.42GHz model?
    memtest
    Memory is ok!
    And these numbers look a bit low (but that might just be because you forgot disable).
  • »23.12.10 - 10:24
    Simon
    Here are the results of my Powermac Digital Audio, equiped with Sonnet 1.8. I could have sworn that a few days ago I passed the memtest with 3x 512Mb and with better results also... but or I am getting crazy or something else is going on, I had to replace the 3rd 512mb with a 256Mb to pass the memtest. All in all not to bad these results and more than enough for what MorphOS is today.
    Ram Disk:> cpu
    System: PowerMac3,4
    Machine: 0x1
    CPUCount: 1
    CPU0: Ticks 4
    Allocated memory at 0x28465D40 -> 0x6C4F59BF, 1141439616 bytes
    Write 552 MB/sec. Verify 397 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 554 MB/sec. Verify 397 MB/sec.
    Memory is ok!
  • »25.12.10 - 17:03
    Ruud
    Here's the results from my 1.42Ghz eMac:
    System: PowerMac6,4
    Machine: 0x1
    CPUCount: 1
    CPU0: CPUClock 1416666661 BusClock 166402287
    CPU0: Ticks 4
    Allocated memory at 0x237C4200 -> 0x4D6BAD3F, 703556416 bytes
    Writing and Verifying 0x00000000... Write 779 MB/sec. Verify 375 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 779 MB/sec. Verify 375 MB/sec.
    Memory is ok!
  • »10.02.11 - 12:44
    stephen_robinson
    Posts: 746 from 2007/4/22
    This is from my Dual 1.42 Powermac, memtest keeps freezing, probably due to having 2 1GB sticks of ram in it??
    Ram Disk:> cpu
    System: PowerMac3,6
    Machine: 0x1
    CPUCount: 2
    CPU0: CPUClock 1416666661 BusClock 166636500
    CPU0: Ticks 4
    CPU0: ICacheL3Size 2097152
    CPU0: DCacheL3Size 2097152
    CPU1: 7445/7455 (G4) Version 32769 Revision 771
    CPU1: CPUClock 1416666661 BusClock 166636500
    CPU1: FPU Unit exists
    CPU1: Altivec Unit exists
    CPU1: Performance Monitor Unit exists
    CPU1: DataStream Unit exists
    CPU1: ReservationSize 32
    CPU1: Ticks 4
    CPU1: CacheL1Type 0x0
    CPU1: CacheL1Flags 0x1000F
    CPU1: ICacheL1Size 32768
    CPU1: ICacheL1Lines 1024
    CPU1: ICacheL1LineSize 32
    CPU1: DCacheL1Size 32768
    CPU1: DCacheL1Lines 1024
    CPU1: DCacheL1LineSize 32
    CPU1: CacheL2Type 0x0
    CPU1: CacheL2Flags 0x1001D
    CPU1: ICacheL2Size 262144
    CPU1: ICacheL2Lines 0
    CPU1: ICacheL2LineSize 0
    CPU1: DCacheL2Size 262144
    CPU1: DCacheL2Lines 0
    CPU1: DCacheL2LineSize 0
    CPU1: CacheL3Type 0x0
    CPU1: CacheL3Flags 0x1001D
    CPU1: ICacheL3Size 2097152
    CPU1: ICacheL3Lines 0
    CPU1: ICacheL3LineSize 0
    CPU1: DCacheL3Size 2097152
    CPU1: DCacheL3Lines 0
    CPU1: DCacheL3LineSize 0
  • »14.05.11 - 15:28
    Divinity
    Posts: 531 from 2009/9/8
    Hi Stephen, there is a problem in MorphOS 2.7 addressing more than 1280Mb (in PowerMac)
    I have same freeze problem in PowerMac FW800 dual G4@1420 with 2048Mb RAM (512Mb x 4).
    You can see also this freeze problem copying file in RAM: volume (more than 1280Mb).
    I hope It' ll be solved this addressing RAM problem in MorphOS 2.8.
    bye
    [ Edited by Divinity 14.05.2011 - 21:29 ]
  • »14.05.11 - 18:08
    stephen_robinson
    Putting files into ram didn't seem to work, but after taking out 1 of the 1GB sticks of ram out:-
    Allocated memory at 0x23D81740 -> 0x5C85E5BF, 950914688 bytes
    Write 697 MB/sec. Verify 394 MB/sec.
    Memory is ok!
  • »14.05.11 - 19:25
    Divinity
    There is a freeze problem (copying file to RAM: for exemple) in PowerMac in MorphOS 2.7, only if you have more than 1280Mb.
    For exemple if you use 1024 x 2 , or 512 x 3 or x 4 , or 1024+512, or 1024+256+256... or 521 x2 + 256 x2 , or etc... so more than 1280Mb.
    @morphos team
    solved in MorphOS 2.8 ?
    Thanks
    Regards
    [ Edited by Divinity 15.05.2011 - 06:51 ]
  • »15.05.11 - 03:47
    stephen_robinson
    You know, I'd completely forgotten I'd posted on here..
    Anyway, I've replaced the 2 gig sticks of generic ram with some quite fancy OCZ PLATINUM PC3200 (OCZ4002048ELDCPE-K) memory, sticks on my Dual G4 1.42 MDD, the results are:
    Allocated memory at 0x22D1EE40 -> 0x5C8495FF, 968009664 bytes
    Writing and Verifying 0xFFFFFFFF... Write 697 MB/sec. Verify 394 MB/sec.
    Memory is ok!
    Which is idnetical to other stuff  :-( Well live and learn..
  • »04.08.11 - 20:21
    stephen_robinson
    450 G4 Cube
    Ram Disk:> cpu
    System: PowerMac5,1
    Machine: 0x1
    CPUCount: 1
    CPU0: 7400 (G4) Version 12 Revision 521
    CPU0: CPUClock 450000000 BusClock 99630669
    CPU0: Ticks 4
    Allocated memory at 0x27806140 -> 0x7C21213F, 1419821056 bytes
    Write 459 MB/sec. Verify 170 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 459 MB/sec. Verify 170 MB/sec.
    Memory is ok!
    [ Edited by stephen_robinson 17.08.2011 - 20:48 ]
  • »17.08.11 - 17:46
    stephen_robinson
    While I'm here, the results for a MacMin 1.5Ghz with 64mb of Graphics ram:-
    Allocated memory at 0x22C81E40 -> 0x5C8E7CBF, 969301632 bytes
    Write 772 MB/sec. Verify 374 MB/sec.
    Writing and Verifying 0xFFFFFFFF... Write 773 MB/sec. Verify 374 MB/sec.
    Memory is ok!
    Ram Disk:> Ram Disk:> cpu
    Machine: 0x1
    CPUCount: 1
    CPU0: 7447A (G4) Version 32771 Revision 261
    CPU0: CPUClock 1499999994 BusClock 166009578
    CPU0: Ticks 4
    And for my 1.67 Powerbook..
    hawh, only joking.
    But I'm suprised that the G4 1.42 power macs memory is slower than the 1.5 MacMini, prehaps , I'm wrong to be suprised?
    [ Edited by stephen_robinson 17.08.2011 - 21:38 ]
  • »17.08.11 - 18:33
    osco
    Posts: 680 from 2009/10/20
    i have same mac mini dual boot..
    a kernal attack can only be avoided by killing the power overnight
    it starts out cool and
    it will then dual boot to the mac side
    the morph side has no problems and my dual boot goes first to Morph :)
    what sticks did you finally get?
  • »17.08.11 - 21:14
    Simon
    Unless you overclock the 167Mhz systembus - that needs PC2700 (333Mhz) ramsticks - faster ram sticks aren't going to do anything noticably to your computer. If you put a faster cpu, the memtest will be better ... but still the PC2700 sticks will handle that without problem. So kind of useless to put expensive sticks in there that are made for people who overclock windowsboxes.
  • »18.08.11 - 06:52
    Brumiga
    Posts: 277 from 2004/4/3
    hello,
    Ram Disk:> cpu
    System: bplan,Pegasos2
    Machine: 0x1
    CPUCount: 1
    CPU0: 7447/7457 (G4) Version 32770 Revision 257
    CPU0: CPUClock 1000000000 BusClock 133333333
    CPU0: ReservationSize 4
    CPU0: Ticks 4
    Allocated memory at 0x3035E1C0 -> 0x5C9599FF, 744470592 bytes
    Write 476 MB/sec. Verify 224 MB/sec.
    Write 476 MB/sec. Verify 225 MB/sec.
    Memory is ok!
    Brumiga
  • »18.08.11 - 11:12
