1TB USB HD
    xyphoid
    Posts: 870 from 2008/7/11
    So I just picked up a slim Western Digital 1TB USB HD pre formatted or windows ntfs (similair to this)
    It won't mount, What gives? morphos 2.6 macmini 1.5ghz 1gig ram
  • »30.11.10 - 14:46
    Posts: 2549 from 2003/2/24
    Well, what does Poseidon say ? (Sytem-prefs/USB) ?
    Does it appear in HDConfig ?
  • »30.11.10 - 14:47
    xyphoid
    no, there is an error
  • »30.11.10 - 14:51
    Golem
    Posts: 766 from 2003/2/28
    @xyphoid
    Once you manage to give us more details about specific errors etc. we might be able to help you. That being said, if it is indeed ntfs formatted you will not be able to write to it.
  • »30.11.10 - 15:08
    xyphoid
    good enough then, it's going back. it mounted on my vista, and my ubuntu.
  • »30.11.10 - 15:14
    Golem
    If it was ext2 formatted you would be able to read/write from all OSes (on windows with a third party ifs). But of course providing actual error messages would still help us determine why it is not mounted read only at least.
    [ Edited by Golem on 2010/11/30 18:23 ]
  • »30.11.10 - 15:21
    Posts: 12521 from 2003/5/22
    > formatted or windows ntfs [...] It won't mount, What gives?
    I had the same problem with my NTFS pre-formatted 0.5 TB PATA HDD in a USB 2.0 enclosure. After re-formatting it to FAT32 using MacOSX I could mount it in MorphOS.
  • »30.11.10 - 15:24
    xyphoid
    yea that was puzzling, I'll try it again later, you need the poseidon error window info, or something else like a log? can't recall exactly, just that the error was in caps
    let me know if info needs to be specific.
  • »30.11.10 - 15:30
    Golem
    Poseidon logs could help, you could also check if the partition shows up in mounter.
  • »30.11.10 - 15:35
    xyphoid
    it didn't show up in mounter.. logs are the window info then? I'll post them when I get back
  • »30.11.10 - 15:39
    MarK
    Posts: 641 from 2004/1/25
    well, i got a 320 gigs usb hdd, it's formated via ntfs, and works flawlessly on my mos 2.5 and 2.6 systems, and also winxp and macosx 10.4 and 10.5...
    bye, MarK.
  • »30.11.10 - 16:11
    xyphoid
    maybe the size 1tb!?
  • »30.11.10 - 16:23
    Had a 1.5TB one working on the Mini, so size is not the problem.
  • »30.11.10 - 16:33
    bash64
    Posts: 974 from 2010/10/28
    More than likely becuase it is preformatted.
    Delete all data on the drive using Windows/Linux...
  • »30.11.10 - 16:52
    xyphoid
    @Andreas & Bash64, maybe I'll do that then after I post the info they need, which I guess will be irrelevant at that point
    [ Edited by xyphoid on 2010/11/30 15:39 ]
  • »30.11.10 - 17:25
    xyphoid
    error logs
    0-hub.class: Device 'USB2.0 Hub' at port 2 is gone!
    0-hub.class: Oh no! I've been shot! Arrggghh...
    0-hub.class: My death killed device 'USB Receiver' at port 3!
    0-hid.class: And don't you come back no more, 'USB Receiver'!
    10-hid.class: Interrupt pipe failed: response timeout (6)!
    5-poseidon.library: Device Logitech Cordless RumblePad 2 probably dropped dead!
    5-poseidon.library: Automatically powercycling port for 'Logitech Cordless RumblePad 2' due death event.
    0-hub.class: Zapping device 'Logitech Cordless RumblePad 2' at port 1!
    0-hub.class: My death killed device 'USB 2.0 Hub [MTT]' at port 4!
    0-hid.class: And don't you come back no more, 'Logitech Cordless RumblePad 2'!
    5-hub.class: CLEAR_PORT_ENABLE failed: response timeout (6)
    10-hub.class: GET_PORT_CONNECTION failed: response timeout (6)
    0-hub.class: My death killed device 'Mass Storage Device' at port 2!
    0-massstorage.class: 'Mass Storage Device' retreated, pitful coward.
    0-hub.class: Time to get rid of 'USB 2.0 Hub [MTT]'!
    0-hub.class: Time to get rid of 'USB2.0 Hub'!
    0-poseidon.library: Device 'USB2.0 Hub' says it is currently bus-powered. Fixing config.
    0-hub.class: New device 'USB2.0 Hub' at port 2. Very nice.
    5-hub.class: Genesys Logic hubs are broken and will cause failures with USB 2.0 devices.
    5-hub.class: If you encounter problems, try the device without the hub.
    5-hub.class: If this solves the problem, you need to buy a different USB 2.0 hub.
    0-hub.class: Hub with 4 ports successfully configured.
    0-hub.class: I'm in love with hub 'USB2.0 Hub'.
    0-massstorage.class: Removable Task stopped.
    0-hub.class: Detected device 'USB Receiver' at port 3. I like it.
    0-poseidon.library: Device 'USB 2.0 Hub [MTT]' says it is currently bus-powered. Fixing config.
    0-hub.class: Detected device 'USB 2.0 Hub [MTT]' at port 4. I like it.
    0-hub.class: Hub has added 2 device(s). That'll be fun!
    0-hid.class: Using HID Descriptor from initial configuration run.
    0-hid.class: HID the road, 'USB Receiver'!
    0-hub.class: I'm in love with hub 'USB 2.0 Hub [MTT]'.
    0-hub.class: Detected device 'Logitech Cordless RumblePad 2' at port 1. I like it.
    0-hub.class: Detected device 'Mass Storage Device' at port 2. I like it.
    5-poseidon.library: GET_DESCRIPTOR (len 8) failed: endpoint stall (4)
    20-poseidon.library: SET_ADDRESS failed: endpoint stall (4)
    20-poseidon.library: Device enumeration failed, sorry.
    0-hid.class: HID the road, 'Logitech Cordless RumblePad 2'!
    0-massstorage.class: Postconfig patchflags 0x0252 ModeXLate RemSupport FixInq36 NoReset.
    0-massstorage.class: MSD 'Mass Storage Device' LUN 0 available through usbscsi.device unit 0!
    0-massstorage.class: Device 'Flash Reader' is of Direct Access type.
    0-massstorage.class: Removable Task started.
  • »30.11.10 - 21:03
    kriz
    Posts: 310 from 2005/10/18
    Yeah dont you just have to reformat as fat32.... And btw. I was wondering about getting a 2TB disk, this is the biggest drive to use with fat32 right?
  • »01.12.10 - 04:59
    xyphoid
    Update, formatting to FAT (using ubuntu) didn't work on morphos nor macOs, but showed up on ubuntu and win. trying ext2 now
  • »04.12.10 - 14:44
    xyphoid
    reformatted on pc, then that wasn't good mac complained about not able to read ignore, initialize, I opened it chose erase which seem like taking forever, so I quit, replugged into my ubuntu, but it came up under the reformatted name, then plugged into morph and it came up.
    one note...the drive only works under direct power from usb, no hubs (I guess unless the hub is self powered) anyway it's good now
  • »04.12.10 - 16:14
