PowerMac G4 MDD compared to MacMini
    JohnFante
    Posts: 158 from 2006/9/4
    This har proberbly been asked before but I was wondering:
    I have a macmini 1,42 ghz, 1gb ram. 32 gb Vram. Nice little machine that runs MorphOS fine.
    I have just been offered a very cheap PowerMacG4 MDD with a radeon 9000 card.
    Besides that the vram on a radeon 9000 is at least 64mb and the PowerMac can take 2MB is there any other advantages with the PowerMac compared to the mini?
    Just wondering :-)
  • »03.12.10 - 07:32
    stephen_robinson
    Posts: 746 from 2007/4/22
    MorphOS 'only' see 1.5 GB of ram, but you've proably noticed that 1GB is more than enough, (unlike Mac OS X), but I did find the increase in graphics ram a big improvement for running mutiple screens. when I got my hands on a 1.5 mac MIni.
    I don't know about the Powermacs, but you can easily fit fast big hard drives, which probably would help as well, so depends how cheap!
  • »03.12.10 - 07:38
    Simon
    Posts: 809 from 2008/7/6
    You just have more options with a "big box" and especially the ability to use a better GPU is worth it.
  • »03.12.10 - 08:32
    analogkid
    Posts: 715 from 2004/11/3
    Unfortunately not yet (maybe in MorphOS 2.8...), but you can use SATA harddisks in Powermac (with a SATA controller in a PCI-Slot.). And, even if the CPU speed of the Powermac is on par with Mac mini's CPU speed, you have the option to upgrade the cpu if you wish (and more important, if you can afford...). And like it was said, you could use a better gfx card, currently the best choice for MorphOS is a Mac Radeon 9000 pro with 128 MB VRAM (this may change with 3D drivers for 9600 - 9800).
    [ Edited by analogkid on 2010/12/3 10:52 ]
  • »03.12.10 - 08:50
    Simon
    can we use SATA now with 2.7 in powermac ?
  • »03.12.10 - 10:44
    SoundSquare
    Posts: 1214 from 2004/12/1
    -> Quote:
  • »03.12.10 - 12:34
    JohnFante
    Ok. Thank you for all the answers.
    The price for the machine is around 100 euro for a version with 1,25 ghz processor, 512 MB ram, radeon 9000, 80 gb hd and gigabit networkcard.
    It sounds cheap but is it?
  • »03.12.10 - 12:54
    pampers
    Posts: 1061 from 2009/2/26
    John: imo it's cheap. I paid 150e for dual 1.42.
    MorphOS 3.x
  • »03.12.10 - 15:05
    bash64
    Posts: 974 from 2010/10/28
    SATA = buy a SATA->IDE adapter.
    Problem solved.
    Got one right here. Bought it so I could plug in a blu ray drive.
    And no...this is not an invitation to discuss bluray!
  • »03.12.10 - 23:36
    scrAb_
    Posts: 62 from 2010/7/23
    wondering Mos performances on a SSD....
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »04.12.10 - 06:26
