Pegasos 2 does not boot
    ozkano
    Posts: 14 from 2009/5/7
    my pegasos 2 is broken a while, I connect via serial port with telnet and it stuck here, any suggestion
    PegasosII Boot Strap (c) 2002-2003 bplan GmbH
    Running on CPU PVR:00083311
    Enable L1 ICache... Done.
    Reading W83194 : 00FFFFFFFFFF0000 Done.
    Setting Front Side Bus to 133MHz...
  • »02.12.10 - 13:11
    matt3
    Posts: 782 from 2004/2/10
    Best guess for me...
    Does your CPU still have the heat sink on it? and does the fan still spin?
    The only weakness that the Peg2s have is the heatsink/fan are prone to failure, the G4 will fry quick without them.
    Good luck!
    Matt
  • »02.12.10 - 15:16
    stephen_robinson
    Posts: 746 from 2007/4/22
    And that's it?
    I'd try replacing, or least resitting the memory.
  • »02.12.10 - 15:19
    ozkano
    I just pass ths problem by changing cpu jumpers, here another problem it gives error on ram segment
    ÿPegasosII Boot Strap (c) 2002-2003 bplan GmbH
    Setting Front Side Bus to 133MHz... Done.
    Configuring DDR... Done.
    Configuring PCI0... Done.
    Configuring PCI1... Done.
    Configuring ETH... Done.
    Releasing IDE reset ... Done.
    Configuring Legacy Devices
    Initializing KBD... Done.
    Testing 10000000 Bytes, Pass: 00000000 Failed: 00000000
    RAM TEST (fill linear)... FAILED.
    ADR : 00000000
    VAL : 200200FF
    00000000 : 200200FF 0002FF84 200200FF 0002FF8C
    00000010 : 600200FF 0006FF94 200200FF 00027E9C
    00000020 : 200200FF 0002FBA4 200200FF 0002FFAC
    00000030 : 600200FF 0006FFB4 200200FF 0002FFBC
    00000040 : 200200FB 0002FFC4 200200FF 0002FFCC
    00000050 : 600200FF 0006FFD4 200200FF 0002FFDC
    00000060 : 200200FF 0002FBE4 200200FF 0002FFEC
    00000070 : 600200FF 0006FEF4 200200FF 0002FFFC
    00000080 : 200200FF 0002FF84 200200FF 0002FF8C
    00000090 : 600200FF 0006FF94 200200FF 00027E9C
    000000A0 : 200200FF 0002FFA4 200200FF 0002FFAC
    000000B0 : 600200FF 0006FEB4 200200FF 0002FFBC
    000000C0 : 200200FF 0002FFC4 200200FF 0002FFCC
    000000D0 : 600200FF 0006FFD4 200200FF 0002FFDC
    000000E0 : 200200FF 0002FFE4 200200FF 0002FFEC
    000000F0 : 600200FF 0006FFF4 200200FF 0002FFFC
    Entering IKARUS low level console
  • »02.12.10 - 15:42
    ozkano
    I cant use console, keyboard does not respond from win7 pc
    http://1.bp.blogspot.com/_KDVGyWcpAvM/TPfmOs71uGI/AAAAAAAABMU/FFuBRZ7oig8/s1600/Pegasos%2B2.jpg
    [ Edited by ozkano on 2010/12/2 20:37 ]
  • »02.12.10 - 15:43
    Golem
    Posts: 766 from 2003/2/28
    Given the output out got there you should try replacing your ram.
  • »02.12.10 - 17:04
    ozkano
    I replaced 3 rams, each ram gives diffrent data
  • »02.12.10 - 17:30
    Golem
    Could you try removing the RAM, then power on the Pegasos, power off and insert RAM, then power on again, this should ensure the firmware configures it properly at least.
  • »02.12.10 - 18:25
    ozkano
    when I removed ram it does not give any error, but when I plugged ram, it does not passed from ram test
  • »02.12.10 - 18:44
    Golem
    Well that's not good, tried using the other slot?
  • »02.12.10 - 18:50
    ozkano
    I tried bot slots, no progress
  • »02.12.10 - 18:55
    magnetic
    Posts: 2129 from 2003/3/1
    What type of RAM are you using? Try pc 2700 and name brand like Samsung, Micron, etc and report back
  • »03.12.10 - 23:16
    ozkano
    MTD PC400 256 MB
    Noname PC333 256 MB
    Noname PC266 128 MB
    Spektek PC2700 256 MB
    these are I tested
  • »04.12.10 - 03:24
    ozkano
    I have just removed mac mini's ram, Kingston brand, it gives same error, it seems main board gone to hell :)
  • »04.12.10 - 03:44
