usb dvd drive not mounting any media
    xyphoid
    Posts: 870 from 2008/7/11
    I can't recall using my usb external dvd re-writer(lite-on) since the upgrade, but it's not mounting anything, though it appears on the usb device list, but messages state trying to mount unit1 via morphos mount.library then all warning msg all the way down simple scsi:filtering scsi command 01 00 00 00 00 ect.
    Any Ideas what's going on?it worked before, to burn and copy copy and is listed on my frying pan, but fp is having issues accessing it too.
    macmini Morphos 2.5
  • »02.10.10 - 21:34
    Golem
    Posts: 766 from 2003/2/28
    Right, now go disable simple scsi in usb massstorage settings for that device again.
  • »03.10.10 - 09:47
    xyphoid
    yea it was disable, then I enabled it which gave the above msgs. so I disabled it again and still nothing, even after re-boot. Works on the osx side.
  • »03.10.10 - 11:45
    Golem
    Mkay.... more details might help us help you.
  • »03.10.10 - 14:41
    xyphoid
    all i get is trying to mount unit 2 via morphos mount.library
    what else is needed? a log of some sort ?
  • »03.10.10 - 16:57
    xyphoid
    not sure what's up with the mounting here as I'm trying again.
    warning massstorage.class Cmd 00 00 00 00 00 00: Sence Key 2/3A/02
    .....and so on, down the line
    inserting new media gets
    ModePage (56) header: 3A 41 00 00 5 32 40 05 08 00 00 00...
    Capacity: Cylinders =5087, CyleSectors=768, Heads=6, TrackSectors=128, Blocks=3906816
    Trying to mount unit 1 via Morphos mount library.
    Is there a mount to put into user-startup or something? I remember doing something when it was attached to my efika then. (It worked under 2.4 on the mini too ) I also installed the sdk pack. Whatever it is, it's reognized as attached, and working, just not mounting!
  • »05.10.10 - 21:25
    Golem
    And this same media mounted before? What is on it?
  • »06.10.10 - 11:35
    xyphoid
    It is a DVD movie, but I also tried with an audio cd, and a different movie. I'll try an old game cd later if you wish. What alerted me to the issue was writing an audio cd from mp3, and the mini wasn't reading the blank media correctly (stated no room with makecd) so I decided to try it on the usb drive, then discovered these issues with mounting.
  • »06.10.10 - 14:45
    xyphoid
    warning massstorage.class Command (00 00 00 00 00) failed:
    error massstorage.class Command block failed: nak timeout (10)
    warning cmd 00 00 00 00 00 00 sense key 2/3A/02
    echos the same errors on data media disk (os3.9)
    repeats continuously.
  • »06.10.10 - 20:40
    xyphoid
    I resurected my old hp dl dvdrw 603e and it works fine, so It's a matte of finding a setting which works for the lite-on then maybe? I'd rathr the lite-on as it is a slim drive which sits on the mini. the hp is bulkier.
    ok fixed it while typing this checked trim inquiry no initial reset translate cmd6->cmd10
    unpluged usb then reinserted
  • »06.10.10 - 22:11
