Little problem updating from 2.4
    kickstart
    Posts: 227 from 2009/4/28
    Hi.
    Im tying to update my macmini but when run iwizard appears a requester saying that i need a efika version (or something, i dont remember exactly now :( ) Im using a usb stick mounting the iso.
  • »27.09.10 - 18:08
    SoundSquare
    Posts: 1214 from 2004/12/1
    that would be easier to help if you could remember exactly : )
  • »27.09.10 - 18:33
    kickstart
    Yeah... sorry i havent the macmini in front of me.
  • »27.09.10 - 18:41
    Golem
    Posts: 766 from 2003/2/28
    And did you boot using the 2.5 boot.img?
  • »27.09.10 - 21:04
    me thinks this is a case of operator error.
    Let us know if you are using the wrong file, or iso image for the Efika on your G4 MacMini, and if not, what progress you make if figuring out what the problem is.
  • »28.09.10 - 06:59
    kickstart
    Im using the macmini version of course... but how i see cannot update from the 2.4 version without booting from 2.5 install iso.
  • »28.09.10 - 21:54
