Can i use External USB dvd writer with mac mini?
    trotter
    Posts: 106 from 2010/1/14
    http://www.netbookreviews.net/news/liteon-etau108/
    I was thinking of purchasing this at maplins tommorrow
    and was wondering if there would be any problem within morphos 2.4
    with it being an external usb dvd rewriter.
    Will it work okay then if not what would be the limitations?
    ie will not burn dvds but ok with burning cds on morphos
    thanks for your time
    Martin N
    Running MorphOS v3.18 on Mac mini 1.5GHz 64meg VRAM,1gig ram.
    Palm T3 pda along with pixel 4a GrapheneOS smartphone. Updated August 2023
  • »06.03.10 - 16:50
    Posts: 2577 from 2003/2/24
    Why not just use the writer that comes inside the MacMini ?
    There is no booting from USB with the Mini...
  • »06.03.10 - 19:39
    trotter
    Because its not reading CDRs only commercially pressed cds.
    I have bought a replacement for the internal mac mini but its seems the pata replacements new are starting to be more difficult to track down new.
    If i can use this with the mini it would help in the future and also i can use it on my old ibm thinkpad and desktop PC.
    Martin N
  • »06.03.10 - 19:43
    kriz
    Posts: 314 from 2005/10/18
    Then the internal wil never work as a burner at all really ? But i understand why so many discs refuse to show now .. Thx
  • »06.03.10 - 21:08
    Golem
    Posts: 766 from 2003/2/28
    Maybe tell us how you reached that conclusion?
  • »06.03.10 - 21:19
    kriz
    If no cdr work, an empty will work ? I have just tried some cds here, and burned seemed not to work ..
  • »06.03.10 - 21:39
    Golem
    So your drive is faulty? Or do the discs work under OSX?
  • »06.03.10 - 22:04
    pampers
    Posts: 1071 from 2009/2/26
    CD drives in MacMinis are known to be really crap... Don't expect anything. Repleacement is not that expensive though...
    MorphOS 3.x
  • »06.03.10 - 22:28
    Posts: 12557 from 2003/5/22
    "booting from USB definitely works. Then whether it also works for USB cdrom drives remains to be seen, but it certainly works for usb sticks, at least. :)"
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=30691&forum=28#537048
    "What's sure is that booting from USB works. I tried it."
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=30691&forum=28#537066
  • »07.03.10 - 01:00
    kriz
    Hehe never tried with osx, just wiped it and installed MOS.. :)
  • »07.03.10 - 13:43
    Korni
    Posts: 473 from 2006/2/23
    That's not a booting from USB directly but loading boot.img from the other supported device and then continuing from a USB device.
    [ Edited by Korni on 2010/3/7 18:19 ]
  • »07.03.10 - 15:13
