Posts: 2072 from 2003/6/4
igracki wrote:
How can I format a partition with fat32 on morphos?
HDConfig only has a FAT entry for Filesystem, when I choose to edit a partition!?
I was a bit too fast and a bit wrong when writing the former post. It is not FAT32 I used, but the FAT provided by MorphOS for Maclayout disks (whatever FAT that is). And as I discovered now (the setup with the external hdd is pretty new) this doesn't work the way I hoped.
So for now there is a HFS+ partition and a sfs partition and a "space for rent" that should do the task of data exchange - which turns out not to be a trivial thing.
[ Edited by Zylesea on 2010/2/16 19:56 ]
