USB to IDE adapter and CDROM on Efika
    Tronman
    Posts: 209 from 2003/3/3
    I bought a USB to IDE adapter today, and plugged it into the Efika with a Belkin USB hub. Poseidon mounts the device just fine, but there seems no way to mount or access the device plugged into it. I quickly searched this site and found no obvious answer, so do I have to make a mountlist? Possibluy a setting in Poseidon?
    Poseidon says 'MSD: USB to ATA/ATAPI Bridge LUN 0 available through usbscsi.device unit 0!'
    Device " is of Direct Access type.
    Device does not seem to use removable media.
    Removable task started.
    SCSI_READ_CAPACITY failed: 45
    Trying to mount unit 0 via MorphOS mount.library
    Maybe the device can't handle a CDROM drive? If it's ATA then it should, but perhaps it needs something else?
    As always, thanks in advance :-)
  • »09.02.10 - 01:11
    xyphoid
    Posts: 870 from 2008/7/11
    a thread actually existed on this setup, but finding it is not my specialty. Not sure if this helps but place a disc in in and listen for access, then check within the cubed Os icon. If it's not on ambient, it may mount there. cdroms on efika are tricky. I've posted a few threads on the topic, but they do work. Don't know if this will help. (there was also something about a mount)
  • »09.02.10 - 01:56
    Posts: 1367 from 2010/1/6
    I've the same problem with a USB-CD/DVD-Writer! It is possible to read data from the CD/DVD using the logical device (CD0:), but there is no way to access the player directly via usbscsi.device.... So it is not possible to access e.g. audiotracks directly with a CD-Player-program to stream them over USB and play them with EFIKAs built in soundchip, nor you can read or write data on a CDR/DVDR with FryingPan......
    Think this is caused by a Poseidon-problem....I've posted this in Pegasosforum, but didn't get any reaction till now....so I am waiting for a solution too.....
    [ Editiert durch Amigaharry2 an 2010/2/9 16:06 ]
  • »09.02.10 - 14:05
    Tronman
    I decided to try it with an actual hard drive-and it works! This is being typed in from an old version of Sputnik run off my Peg I's hard drive.
    So the adapter works fine. I guess it's just meant for hard drives :-/
    Though I must say that it seems pretty snappy even with the Efika's USB ports.
  • »09.02.10 - 14:48
    Golem
    Posts: 766 from 2003/2/28
    Try disabling Simple SCSI or whatever it's called in Poseidon.
  • »09.02.10 - 14:56
