SATA on MOS?
    Dreamcast270mhz
    Posts: 152 from 2009/12/8
    I haven't seen much on this subject, does MOS support SATA/SAS controllers added via PCI? Reason I ask, I may get PMAC g4 for upcoming 2.5 and want SATA for leopard/MOS super speed. If there is a certain controller I need to get, please let me know :)
    My Macs:
  • »18.01.10 - 22:35
    magnetic
    Posts: 2129 from 2003/3/1
    There is no Morphos support for SATA atm. You could use an IDE<>SATA bridge though..
  • »18.01.10 - 22:53
    Dreamcast270mhz
    uuuh yeah not the point. Anyways, if no sata support in 2.5 i'll have to get ultra ata 133 card or a fast SCSI card for pci. Oh well, worth a try.
    My Macs:
  • »18.01.10 - 23:38
    Golem
    Posts: 766 from 2003/2/28
    Those cards will of course also require drivers to function under MorphOS.
  • »19.01.10 - 00:09
    Dreamcast270mhz
    yeah, i'll get a supported model.
    My Macs:
  • »19.01.10 - 00:16
    You're not going to see a significant boost using a PCI ATA133 controller over the built in controller (which depending on the PowerMac model you choose would be either ATA66 or ATA100). ATA133 hard drives will operate on either of those earlier interfaces and in testing those drives on those interfaces I've found minimal impact from the slower interface.
    In plain fact, ATA133 hard drives rarely max out the bandwidth of their interface.
  • »19.01.10 - 18:12
    Posts: 12472 from 2003/5/22
    > ATA66 or ATA100
    Just for completeness's sake: The smaller variant (PCI version) of the first PowerMac G4 has ATA33.
    http://support.apple.com/kb/SP122
    I'd go as far as stating: never :-)
  • »19.01.10 - 19:32
    Good point Andreas,
    I didn't consider those because of their low processor speeds, but they'll probably be supported as well.
  • »19.01.10 - 20:11
    Dreamcast270mhz
    Low cpu speed to me is 600mhz or less, 650-1.9 is okay, beyond that is great in terms of macOS. But, i'll take this to heart. i will get a G4 with the ata 100 because I plan on putting at 200gb drive in my mos machine at least, need to beat my old workstation's HD size :).
    My Macs:
  • »19.01.10 - 22:56
    That's what I'm aiming for myself. Somewhere between 1 and 1.42 GHz with ATA100 an controller. Basically that would be one of the last Powermacs, but they're so common that even these aren't that high priced.
  • »19.01.10 - 23:42
    magnetic
    Dreamcast
    I have Symbios Logic 895 UWSCSI controllers IN STOCK with Full Morphos support up to 80mb/s transfer rates! $34.95! Let me know... only 2 left..
  • »20.01.10 - 06:19
    dIGIMAN
    Posts: 273 from 2005/11/7
    Just wanted to remind, i had major trouble when using a scsi controller in the peg together with more memory then 512mb.
    I tested serval ones. 512mb, everythig ok. 1 gb, the system went crazy (the debug log got written full).
    And no, it was not the memory modul.
  • »20.01.10 - 07:45
    Is 80mb/s that much faster (considering the cost of SCSI drives). I know a 10,000 rpm SCSI drive is fast, but how much faster than say a WD Raptor, would that be?
    I assume your talking about a PCI controller. How do we contact you if someone wants to buy it?
  • »20.01.10 - 10:45
    I would suggest PM.
  • »20.01.10 - 11:44
    Painfully obvious (if I'd only looked at the link at the bottom of each message).
    Thanks again, Andreas.
  • »20.01.10 - 17:46
    magnetic
    Hey Jim
    Not sure about the 10k scsi drive vs Raptor but i'm guessing maybe raptor is faster - though you can get SCSI drives cheap now.. I actually have a 10k rpm Cheetah Seagate drive I can include as a package deal.
    We sold a lot of these boards when Amiga guys were migrating their Amiga drives to Pegasos!
    And yes its a PCI controller and very well made the connectors are metal they dont make cards like this quality any more!
  • »20.01.10 - 20:22
