wifi pegasos2 prism or wireless ethernet bridge
    amiga4001
    Posts: 454 from 2006/11/16
    I am looking into wifi for setting it up on several computers in my home.
    2 Windows machine and off course a pegasos2.
    What is my best chance: Go for a wireless ethernet bridge or search for a prism2 pci wifi card?
    Can anybody recommend a type/brand bridge or wifi prism card?
    Or is usb possible somehow?
  • »06.09.09 - 14:26
    Krashan
    Posts: 1107 from 2003/6/11
    I would recommend a bridge. If you use a WiFi card in Pegasos, you will be forced to use WEP encryption on your wireless network, because MorphOS driver does not support WPA and WPA-2. WEP encryption is very weak and easy to break in minutes.
  • »06.09.09 - 16:13
    Posts: 33 from 2003/6/17
    Hi, I use a Multi-function Wireless Access Point with a client mode. You only have to configure the client mode and log in with it. You can go to the internet via ethernet.
    This model has two LAN-Ports.
    http://www.airlive.com/product/product_3.jsp?pdid=PD1217473992975
    Perhaps there are other models with more ports.
    It works perfectly for me.
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »06.09.09 - 18:21
    amiga4001
    Thanks for the tips.
    I go for the bridge and I already ordered one:
    The asus 330gE the one they use in the german thread only this one uses wap2 and has a better antenna.
    Hope it will work and next holiday I can also use the wifi provided one several locations.
  • »06.09.09 - 18:57
    Posts: 98 from 2004/6/4
    I'm using this one. Works perfect for me D-Link DIR-300
    WBR, Vladimir Berezenko
  • »07.09.09 - 02:54
