Just blew up my Efika.
    pan1k
    Posts: 147 from 2009/1/20
    So mad right now. I hooked it up with the PCI video card in reverese.. POOF! No more Efika.  :-D  :-x
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »03.02.09 - 01:03
    xyphoid
    Posts: 870 from 2008/7/11
    Damn pan1k what the h*ll how'd you manage that?
  • »03.02.09 - 01:50
    pan1k
    I don't know. I had it running for about 4 hours. Came home, and in excitement, put it back together, whywhywhywhywhy!
    F*ck it, i'll throw it in the gutter and go buy another...
  • »03.02.09 - 01:52
    xyphoid
    yea might be $99 still at Directron though you may also need a new graphic card
  • »03.02.09 - 02:05
    Painkiller
    Posts: 128 from 2007/11/19
    Sad to hear?
    PICS? :flame:  8-D
  • »03.02.09 - 03:54
    pan1k
    It looks normal.. no burnt traces or anything i can see..
  • »03.02.09 - 04:06
    Painkiller
    Have you tried a different graphics card?
  • »03.02.09 - 04:17
    pan1k
    Yeah, I have a 9200 card. Funny thing, the Efika powers right up now, I don't have to use the power button. Blank screen, usb lights up, NIC LED's light up.. I can heard the hard drive spin up.. just no video :(
  • »03.02.09 - 04:39
    CountRaven
    Posts: 566 from 2007/12/10
    It is probably the gfx card and not the efika that died...
  • »03.02.09 - 05:57
    Painkiller
    If I recall correctly after power loss the Efika will powerup automaticly. How long have you waited for the picture to show up with your "new" gfx card? What output are you using VGA or DVI?
    [ Edited by Painkiller on 2009/2/3 10:17 ]
  • »03.02.09 - 06:16
    Posts: 2077 from 2003/6/4
    Seems worthwile to ,e to hook up a serial cable and monitor the debug output.But I doubt the efika survived a flipped pci card.
    Sorry to hear your bad luck. Did you have MorphOS registered already? If so (& if the Efika is really dead) contact the MorphOS-Team to manage a license transfer.
  • »03.02.09 - 06:35
    pan1k
    My PCI card is probably dead. I tried the AGP riser and no video.. i took the battery out, it's been sitting on my desk over night... I guess I can try to hook it up tonight..BOOO!
    I also ordered a replacement... should be here in 3-4 days...
    [ Edited by pan1k on 2009/2/3 8:38 ]
  • »03.02.09 - 14:24
    BinoX
    Posts: 5 from 2008/7/9
    If you're in the UK, if you send it down to me, I can have a look at it and have a bit of a fiddle if u want :)
    If you're not in the UK, fancy selling it to me for the cost of shipping it over here? And at the worst I can use the PCI slot and other connectors on it for other projects :)
    Edit: Although before that.. try a different power supply, you may find that the card being in backwards grounded something some place wrong and has blown one of the fuses inside the PSU
    [ Edited by BinoX on 2009/2/3 16:53 ]
  • »03.02.09 - 14:47
    pan1k
    OK, might sell it to you for shipping.. I'm going to hook a serial cable up to it.. and see what I get...
  • »03.02.09 - 14:53
    pan1k
    Well.... connected the serial console and.... nothin! :(
  • »04.02.09 - 14:06
    BinoX
    Damn :(
    It's horrible when hardware blows up. At least they're not too expensive
  • »04.02.09 - 14:14
