Best 1gb Ram module for Peg2??
    magnetic
    Posts: 2129 from 2003/3/1
    Hey guys
    I'm looking to get a 1 gb Ram module for my peg. Can you guys please report what ones you are using here?
    tia
  • »04.05.08 - 06:40
    stephen_robinson
    Posts: 746 from 2007/4/22
    Bump!
    I was thinking of getting 2 DDR 1 gb sticks for my peg2, anyone out there know which brands work?
  • »13.09.08 - 12:36
    Derringer
    Posts: 103 from 2008/8/4
    Here Transcend 1GB/400MHz which is one sided module works perfectly.
    Unfortunatelly i have only one module of rhis.
    I tried Kingmax 1GB/400MHz doule sided, which is not worked in pair. So only one module works at a time.
    I will try to check with one sided modules. Somewhere i read peg one is like only one sided modules, maybe this is for true for peg2.
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »13.09.08 - 19:53
    Derringer
    today i run several tests with transcend kingstone, kingmay modules.
    My peg2 only handles 1,5GB memory. I have only 2 sided memory modules, so who knows maybe one sided is the perfect solution.
    1gb+ 512mb not works.
    1gb kingmay (or kingstone) on the first slot + whatever 1gb on the second slot will only give 1,5GB memory.
  • »13.12.08 - 12:34
    Posts: 2564 from 2003/2/24
    MorphOS only recognizes 1.5GB max. (dunno why), soyou might want check with another OS.
  • »13.12.08 - 13:22
    r1vver
    Posts: 14 from 2008/9/30
    http://www.powerdeveloper.org/forums/viewtopic.php?t=424&highlight=openfirmware
  • »13.12.08 - 15:49
