Where do I obtain the latest Pegasos2 firmware?
    fairlanefastback
    Posts: 54 from 2007/2/6
    I seem to be a version behind. I checked the Pegasos book at Efika.org, the Genesi website too. Maybe I am missing something?
  • »04.07.08 - 03:14
    Posts: 1086 from 2003/3/24
    You have to contact bPlan for a Firmware update.
  • »04.07.08 - 08:53
    gaz_god
    Posts: 15 from 2006/4/17
    I got my firmware update from Gunne at GSS-Data, If my memory is correct i had to supply him with the serial number from my peg cpu.
    Gaz
    http://www.lincsamiga.org.uk
  • »04.07.08 - 12:22
    Senex
    Posts: 500 from 2003/2/17
    As ThePlayer already mentioned, you have to contact bplan about it, specifying the serial number from the CPU card and maybe also the revision of the board itself.
    But if your board is from the very first batch like mine, then there won't be a newer revision than the one once forwarded by GGS Data, i.e. from 08/2004, IIRC (am at work ATM), since in the meantime some board component was exchanged.
    In any case, please always check with bplan instead of simply "trying" some firmware update from someone else, as the newer ones are not compatible with all board revisions.
  • »04.07.08 - 12:51
