Posts: 408 from 2004/7/15
1. Don't put the same stuff in both MOSSYS:DEVS and DEVS:. Put it only in one place. The proper place is DEVS:, MOSSYS: is intented for MorphOS components and not for 3rd party things. Avoid modifying it as long as possible.
2. Forget about DEVS:Mountlist. It's obsolete thing and it's still there for legacy purposes only.
3. Do you have 'NoClick mode' activated? If so, the driver won't detect disk insertion by itself, you'll have to kick it using 'DiskChange DF0:' command after you insert a disk. It's hardware limitation, there's no way to implement silent autodetect.
iPod, iBook, iMac,... iRobot?
