MorphOS random freeze/lockups!
    Dragster
    Posts: 99 from 2005/11/6
    Hi, finally now that I've been able to make MOS boot everytime it turn out that randon lockups occur. Once it boots, it happens that even while the system is idle (I'm not doing anything in it) MOS just freezes.. this happens at variable time, sometimes it happens almost immediately, other it takes a few minutes before freezing..
    My setup: Amiga 1200T with BlizzardPPC 603e+ and 256 MB RAM. BVsion and MOS running on SCSI HD connected tothe boards' controller.
    i can provide any details or more information if required.
    thanks!
    D.
  • »30.01.08 - 00:55
    MarK
    Posts: 641 from 2004/1/25
    and what You mean, it freezes? when i had incompatible dimm modules in my peg2, it sometimes happen, that the trance took 100% of cpu... and after some time, it was okay again... stopped to happen, when i removed second dimm module. but as You have blizzard, it's probably another problem with trance? execute the system monitor, and watch, when it will freezee, if it's the trance, or something else... if possible, ofcourse.. then you can solve other stuff...
    bye, MarK.
  • »30.01.08 - 04:35
    kriz
    Posts: 310 from 2005/10/18
    Did the Bvison work fine os3 ? I also had a bvsion, and it locked up all the time..
  • »30.01.08 - 05:24
    jcmarcos
    Posts: 1178 from 2003/3/13
    There is one case like yours in a thread over here somewhere. It was about a guy who had an Amiga 1200 that worked flawlessly with AmigaOS 3.9, but failed with MorphOS PowerUP.
    It has to be software, because hardware is same. No! It turned out that a weak power suply was to blame.
    It didn't matter with AmigaOS 3.9, as it uses less resources, namely the PowerPC CPU in the PowerUP card. But MorphOS stressed more the system, which demanded more power, which results in a voltage drop. This always has amusing effects in computers.
    Yes, you can use MorphOS to make test benches for power supplies.  :-)
  • »30.01.08 - 06:16
    Dragster
    @Mark
    Well, it just locks up. Even the titlebar clock stops... really don't know why, because m systems runs OK with OS3.9 and.. ahem, OS 4... I'll try to see if there a system process eating all the CPU randonmly, but i really doubt it, because when this happens I can not even move the mouse pointer anymore.
    thanks,
    D.
  • »30.01.08 - 12:20
    Dragster
    @Kriz
    Yeah, it works fine in OS 3.9 hehe...
    cheers
    D.
  • »30.01.08 - 12:21
    Dragster
    @JCMarcos
    Thanks for the tip but.. well, I have my 1200 mounted in a power tower and I'm using a 400 WATT ATX Powersupply... eventhough my A1200 is fully loaded, I'll try to disconnect some stuff to test... I even have the PSU connected to the mobo via the floppy power connector!
    Thanks!
    D.
  • »30.01.08 - 12:24
    Framiga
    Posts: 363 from 2003/7/11
    what Ambient and MUI version are you using?
  • »30.01.08 - 13:36
    Charvel
    Posts: 97 from 2007/2/15
    I had the exact same problem with my A1200T.
    I never solved it before my BPPC went down but I was 99% sure that it
    was heat problems.
    I had a 040/25 (which produces a lot of heat) and a BVision.
    The BVision also got VERY warm. Try and cool down the memory on the
    BVision. It might help. I could easly cook dinner on that BVision when
    using MorphOS :)
    For me, my card never worked in 3.9 as it should but under MorphOS it
    worked just fine. For 5min up to an hour :)
    Then it freezed.
  • »30.01.08 - 14:10
    MarK
    well, under the peg2, also everything freezed, but after a minute or sth like that, it was okay... for, say, few minutes...
    bye, MarK.
  • »30.01.08 - 14:43
    Posts: 2074 from 2003/6/4
    IIRC I heard something that the floppy power connector is not always sufficient to pass through enough amperes and it is suggested to add a second paralell power input at some other place.
    But beware of loops and short circuits , it's easy to fry up your board.
  • »30.01.08 - 15:00
    AmigaMancer
    Posts: 265 from 2005/8/25
    @Dragster
    Well, since you run OS4 too, you can give a definite answer on if the problem is hardware or software related. Does OS4 run stable?
    [ Edited by AmigaMancer on 2008/1/31 18:56 ]
    Amiga 1200 user.
  • »31.01.08 - 14:51
    Adam_K
    Posts: 34 from 2006/3/31
    About two years ago I had simmilar situation. Many people adviced me in my problem. Try to read this posts - maybe some advice will be good for you...
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=42&topic_id=4771&sortname=&sortorder=&sortdays=&viewmode=flat&order=0&start=0
    In my case the problem was with no properly SFS version. Read about it also on link below.
    Then try to your all HD partisions SFS original releases from Hendrikx (version 1.84). Maybe it helps...
  • »31.01.08 - 20:27
