Posts: 350 from 2003/10/12
I'm still leaning towards firmware issue.
Possible. There was some nvram script, which should increase the drive detection delay, thus enabling drives to be detected properly. I can't give a link ATM tho'.
Even if the problem isn't there it would be nice to know where to get the updates and how to update it.
There's no newer publicly available firmware, than the one on bPlan's site. Which is the same you've already got with the machine. There were some 1.2 versions floating around "unofficially" tho. Try to get one. But be prepared, that a firmware upgrade can not only solve problems, but *trigger new ones* (f.eg. USB, video and memory compatibility problems).
