200+ GB hard drive and MOS-any Gotchas?
    Tronman
    Posts: 209 from 2003/3/3
    So the not-so-trustee forty gig hard drive in my PegII died :-( May God rest its soul along with all those mp3s..
    Stay away from Hitachi Deskstars, btw, I've now had two of them go tits up in a year..
    It's now getting to the point where it is hard to find a sub-130 gig drive, and I can get a 200 gig drive for about seventy bucks. So, if I get such a drive, can I just format the whole thing with MOS toolkit? Do I have to break it up into a boatload of four gig chunks? Or, can I just have like 100 for MOS and the other hundred for Linux if I'd like, or can the whole thing be MOS?
    I know that much space is overkill until firewire port drivers and modern video edit software comes to MorphOS, but I'm just wondering what the limitations are with modern, huge capacity drives. I can get 300+ gigs now so cheap, it's more worth it to just not use the whole drive than it is to try and find a small drive these days.
    Edit: This is on a PegasosII G4 by the way, if that matters in terms of the hardware and 137+ gig drives. Does it?
    [ Edited by Tronman on 2007/11/26 21:53 ]
  • »27.11.07 - 03:52
    Golem
    Posts: 766 from 2003/2/28
    MorphOS and Open Firmware have LBA48 support, so there's no issue using large drives, but depending on which filesystem you plan to use there may be some partition size limits. SFS limits you to 128GB and for partitions larger than 64GB you need to use 1K blocksize. FFS I'm not aware of any such limit, but blocksize and buffers should probably be adjusted. PFS3 has a limit of 104GB per partition.
  • »27.11.07 - 04:44
    nine
    Posts: 46 from 2006/6/14
    @Golem
    Does it? I'm using a 160GB Seagate SATA drive (via an IDE to SATA adapter), and have a single SFS partition. It doesn't appear to mind the partition size at all.
    At least, I haven't had any warnings...
  • »27.11.07 - 06:24
    Golem
    You wont get any error creating it, did you actually fill it and verify the contents?
  • »27.11.07 - 06:50
    tokai
    Posts: 1289 from 2003/2/25
    ... for partitions larger than 64GB you need to use 1K blocksize.
    That's the first time I hear this. U sure? :) I happily run a 103.7GB partition with 512er blocks (and yes, almost filled to the dead end :) )
    regards,
    tokai
  • »27.11.07 - 07:58
    tokai
    You never can have large enough drives. If you don't want a 500 GB one please buy one anyway (for me) and I'll send you a small 40GB one in exchange. :-)
    regards,
    tokai
  • »27.11.07 - 08:05
    Golem
    Maybe I got confused by some 68k SFS discussions, I tried various setups a while back... can't find my notes now :)
  • »27.11.07 - 10:32
    Posts: 2217 from 2003/2/24
    At least I want to play for sure and I've always used 1024 blocks and kept partitions under 128GB.. never had any problems with those :)
  • »27.11.07 - 11:44
    Jupp3
    Posts: 1193 from 2003/2/24
    I guess it's worth noting that MorphOS 1.4 has problems with hard disks over 128GB(?) - basically when you write data to partition beyond that limit, it "wraps around" and ends up corrupting data elsewhere on the drive.
    The good news is that this (among few other critical things) got fixed in MorphOS 1.4.3(?) update. So make sure you're using the most recent version before you proceed :-)
    (If you want to have Linux on the same drive aswell, you could put that at the end of drive)
  • »27.11.07 - 11:45
    hooligan
    Posts: 1948 from 2003/2/23
    Beginner. I had five of them replaced by quarantee. They are not called Deathstar for no reason ;-)
    Actually the story goes even further, IBM was sued because of one Deathstar-model
  • »27.11.07 - 13:41
    Tronman
    Heh, yeah I remember that. Supposedly the Hitachi ones were better. Supposedy..
    Anyway it looks like I'm OK, if I just update to the latest MOS before putting very much data on the drive. Well I might reserve 100 gigs for Linux and use the first 100 for MOS. I just remember back in the 68k days when greater-than-4 gig drives got cheap al of a sudden, and there were probs with FFS, etc. Looks like those days are past now :-)
    Thanks, I'll get me a modern drive as soon as I can now.
  • »28.11.07 - 04:21
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    [ Edited by Darth_X on 2007/11/27 23:10 ]
  • »28.11.07 - 05:06
    Daff
    Posts: 250 from 2003/4/5
    You can use 128 Go partition safely on MorphOS with SFS.
    But I've a 500 GB HD (Seagate Barracuda) since some months and it is not entirely recognized. I was obliged to enter manually drive geometry to maximise the available size (4xx GB).
    By defaut SCSIConfig set this HD with 256 GB.
    Anyone have tried with 1 TB HD ?
    [ Edited by Daff on 2007/11/28 11:51 ]
    http://obligement.free.fr
  • »28.11.07 - 08:51
  • mk
    mk
    Posts: 72 from 2004/5/24
    > by Daff on 2007/11/28 11:51:26
    Problem with SCSIConfig
    Optimal geometry has a bug. Maximum 32767 Cylinder be calculated.
    Solution
    Set cylinder manualy to higher value.
    If you reduce the difference used/total sectors to minimum, then you can also use big HD fully.
  • »28.11.07 - 09:37
