English manual for pegasosII? pin info mainly...
    keropi
    Posts: 131 from 2006/11/11
    Is there an English manual for the pegII mobo? All I have is the german one... I want to connect to the pins with SAFETY a front USB port that exists on my case...
    thanks!
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »29.06.07 - 18:09
    liquidbit
    Posts: 408 from 2003/10/12
    IRC is your best friend!
    join the MOS irc channel  8-)
  • »29.06.07 - 18:36
    keropi
    LO man!
    what server/channel?
    A4000D CS-PPC/Zorro
  • »29.06.07 - 18:41
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    irc is #morphos on freenode.net
  • »29.06.07 - 18:47
    magnetic
    Posts: 2129 from 2003/3/1
    keropi
    Morphos channel is great support for you :-)
    Also, if you have FTP access to the MOS ftp site you can download the manuals AFAIK..
    magnetic
  • »29.06.07 - 21:40
    Senex
    Posts: 500 from 2003/2/17
    @keropi
    I suppose you mean the bplan manual then, since the requested info doesn't differ between my german translation of the Genesi manual and the english one.
    The corresponding image can be found here.
    If you need the english Genesi manual, though, just send me an e-mail.
    [ Edited by Senex on 2007/6/30 11:26 ]
  • »30.06.07 - 05:42
    keropi
    yes, I mean the bplan manual...
    I will email you, the pic above is perfect  :-)
    A4000D CS-PPC/Zorro
  • »30.06.07 - 06:35
    Senex
    @keropi
    As just mentioned in my e-mail, I don't know if an english version of the bplan manual does exist at all.
    Thus all I could provide is the Genesi one.
  • »30.06.07 - 06:47
    DJBase
    Posts: 745 from 2003/4/6
    Well, I don't know but...you could check the Docs-Folder on your MorphOS 1.4.5 CD...
  • »30.06.07 - 06:55
    koan
    Posts: 303 from 2005/11/21
    Is this what you are after ?
    http://www.pegasosppc.com/support.php
    See the links in the middle box.
  • »03.07.07 - 05:57
    keropi
    THANKS!  :-)
    A4000D CS-PPC/Zorro
  • »03.07.07 - 14:52
