USB 2.0
    Posts: 408 from 2004/7/15
    I am going to buy a USB2.0 card. Who can share his experience with them?
    I have at least two choices. First of them is STLab U142 (uses NEC D720101GJ chip) and second of them is VIA VT6212 which is twice cheaper.
    What works and what doesn't? Both in MorphOS and Linux.
    iPod, iBook, iMac,... iRobot?
  • »28.02.07 - 09:57
    MarK
    Posts: 641 from 2004/1/25
    hello there!
    i got one usb2 card from compcity.nl, a via one... then i bought a nec card based on some recomendations... but pegasos2 refused to even boot with it... then i got another via usb2 card, which seams to work good...
    bye, MarK.
  • »28.02.07 - 11:00
    Motosampy
    Posts: 199 from 2004/8/14
    The 2.0 driver is developed for NEC cards, so I'd go with NEC. I have a VIA card in y PegII, and e.g. printer does not work if connected to the 2.0 card, have to quite often unplug and then replug my card reader to get it work, and atm I can't get my mobilephone to work as massstorage.device if connected to the 2.0 card. All these work wihtout any problem with the PegII builtin USB1.1
  • »28.02.07 - 11:57
    matt3
    Posts: 782 from 2004/2/10
    Hi Sonic:
    Similar to what the other guys have suggested. I would probably go with NEC since it was developed for that chip.
    I have tried a bunch of different usb2 cards. In the end I'm using a VIA card. (Sorry don't have any info on cards right here). I found the newer the card, the better chance it was going to work.
    My Peg 2 is currently dead, so I can't test the cards anymore...
    Good luck,
    Matt
    [ Edited by matt3 on 2007/2/28 9:26 ]
  • »28.02.07 - 12:25
    SoundSquare
    Posts: 1214 from 2004/12/1
    it's just funny that everyone is recommending a NEC card but run a VIA one :-)
  • »28.02.07 - 13:45
    Golem
    Posts: 766 from 2003/2/28
    I'm using a NEC card here, tried VIA and ALI cards as well. NEC performs best, ALI is second and VIA was simply too unreliable for regular use.
  • »28.02.07 - 15:09
    Posts: 108 from 2005/4/3
    Hi all,
    The spiderUSB2 from Elbox, an Amiga vendor, works too. I read this in another
    USB2 forumposts. So, if i want an USB2 card, i shall choose for the Spider;
    http://www.elbox.com
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »28.02.07 - 16:12
    Posts: 2547 from 2003/2/24
    @Amigaharry
    Hmm paying Hellbox 79Euro (+p&p) for what can be bought locally at 10-15Euro sure sounds like great idea .....
    @Sonic
    just today I bought a card with the exact same NEC chip for 11.08Euro , 4 external 1 internal works like a charm.
  • »28.02.07 - 16:52
    merko
    Posts: 328 from 2003/5/19
    I got a NEC card, and the Peg2 refuses to boot here too. Some problem
    with the OF it seems.
  • »31.03.07 - 14:01
    Posts: 1932 from 2003/10/19
    I use an NEC card here, DO NOT get a spider. Its just a generic NEC based card that Elbox flashed and rebadged. They charge way more then its worth.
    Also you need to register posiedon and get a keyfile to use a USB 2.0 card or you will suffer time outs after several MB of data moves through the card with any device connected to it.
  • »31.03.07 - 23:57
  • rms
    rms
    Posts: 606 from 2004/11/27
    after testing several types of USB 2.0 cards (well I tested 5 different ones) I found that the Exsys card which has 3 ext. + 1 int. port was the best/most stable.
    I use the card now for several month without any problems. The chip is a NEC 0720101GJ.
    Here is a link to a picture of it.
    http://www.rmsvideo.ch/public_rms/morphos/exsys_usb2_card.jpg
    Regards
    Christoph
  • »03.04.07 - 04:02
    thefab
    Posts: 92 from 2003/8/19
    hmmm, doesn't boot here as well with an usb card
    (or it kill my internal usb :)
  • »03.04.07 - 05:51
    nine
    Posts: 46 from 2006/6/14
    Crikey. I've had an NEC chipset USB2 card plugged into my Peg2 since September and I never knew it was supported.
    Damn. Want to get home to try it now!
  • »03.04.07 - 13:09
  • Ex-Member
    Posts: 74 from 2004/6/15
    Try to disable usb support in open firmware (something like "setenv usb-enable? false"). This worked for me.
    Bye...
    Chris Hodges
  • »03.04.07 - 16:52
    merko
    That fixed it indeed. Unfortunately Poseidon says "Ignoring
    automounting request: Blocksize 2048 bytes (CD or DVD?)" when I plug
    in my mp3 player. No idea how to non-auto mount it either. :)
  • »04.04.07 - 17:13
    merko
    Still no luck. Giggledisk gets only read error on the device (after
    trying for a long time). It works just fine in linux though. I guess
    it should be possible to get some useful info from linux, but I have
    no clue how to do that. Anyone has some hints?
  • »08.04.07 - 14:50
    Motosampy
    I guess this might be Poseidon related issue and is most likely fixed in v3.6 , but you'll have to wait or MOS1.5, since Poseidon 3.6 will most likely not be published separately for MorphOS...
  • »08.04.07 - 16:03
    amiga4001
    Posts: 454 from 2006/11/16
    I've got a nec card.
    Workes ok for some things others not.
    Not printer or digital camera.
    Does work with a mp3 player usb stick(1GB).
  • »08.04.07 - 17:51
    Golem
    Hmm?
  • »08.04.07 - 18:36
    winterhunter
    Posts: 204 from 2005/10/13
    I've just bought a NEC card from relec. Do I need to install any
    drivers to get it to work? Poseidon (v3.3) does not even realize that
    something new is plugged to the system.
    Thanks!
  • »01.06.07 - 12:24
    BatteMan
    Posts: 290 from 2003/2/24
    Winterhunter : If your card is not recognized, you can put parameters in Poseidon yourself. Look this screenshot :
    PS : Si tu veux des reponses en francais, pense a AI ;-) (accents sucent ici ;-) ).
    [ Edited by BatteMan on 2007/6/1 7:42 ]
  • »01.06.07 - 12:41
    Golem
    Yes, you can get the drivers here. You should install both for a nec card. And remember to register poseidon if you haven't already.
  • »01.06.07 - 13:01
    winterhunter
    I have installed the SUB drivers from Nicolas DET, and i have declared
    the devices as follows:
    Name Unit
    uhciusb.device 0
    uhciusb.device 1 (this one and the above are the peg MB)
    ehciusb.device 0
    ohciusb.device 0
    ohciusb.device 1
    That is all I can get Poseidon to recognize on my NEC card (from
    Relec).
    However, when I plug ANYTHING into it, the port dies after some MBs...
    Any ideas why?
    (BatteMan : oui, les accents puent ici :-D)
  • »01.06.07 - 13:04
    SoundSquare
    @winterhunter
    have you registered Poseidon ?
    I have the same issue here but with a VIA card so i don't worry much about it. I' m a registered user.
  • »01.06.07 - 13:21
