jcmarcos wrote:
I have a similar problem with SD cards: I have to format them under MorphOS, if I format them with the camera, they are not recognised as FAT formatteed. More precisely, Poseidon 3 recognises the volume, but it does not mount it automatically. Can anybody here post a "mountlist" file, to mount it manually?
If they're partitioned with a DOS partition table and use FAT, make sure you have a FAT filesystem handler installed, and that Trident knows the filename of the filesystem you are using (everyone seems to recommend FAT95 from aminet, but since I don't use DOS or Windows, I just write native Amiga FFS in Linux instead).
