Set time an Pegasos 2
    JohnFante
    Posts: 163 from 2006/9/4
    For some reason my Pegasos 2 clock is at the wrong time.
    How do correct that in the firmware?
  • »11.02.07 - 11:30
    tokai
    Posts: 1289 from 2003/2/25
    You can do that in MorphOS. Just open the System Preferences and go to the Time page, set correct time and hit "Save".
    Additionally I suggest you to install a tool which can get the time from the internet (NTPSync or FACTS). Depending on your TCP/IP stack you usually can configure it, so it gets automatically started when the TCP/IP stack goes online. That way your clock is always correct.
    The hardware clock goes wrong sooner or later anyway. So syncing it with an internert clock usually helps to avoid beeing in the past or future. :)
    regards,
    tokai
  • »11.02.07 - 11:39
    JohnFante
    Thanks! Works like a charm!
  • »11.02.07 - 16:21
