DVD burn drive compatible with fryingpan
    amiga4001
    Posts: 454 from 2006/11/16
    I connected a NEC DVDrom drive to get it going on my pegasos.
    But nothing not with makecd or fryingpan.
    So I'll have to see for an other one.
    Can you guys recommend me a brand and type which is compatible with Fpan?
    Maybe I better go for a DVD ram drive now while I am at it.
  • »14.01.07 - 19:01
    Posts: 1086 from 2003/3/24
    I use the NEC ND3500 DVD-Writer with FryingPan and it works great, and don't forget that the FP demo can't burn a DVD!
    And wich Nec DVD-Burner are you using?
  • »14.01.07 - 20:35
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    I use a Pioneer DVR-109, and it works fine with FryingPan (and with MakeCD, too).
    [ Edited by DoctorMorbius_FP on 2007/1/14 23:53 ]
  • »14.01.07 - 20:52
    amiga4001
    It is a NEC -DV 5800E.
  • »15.01.07 - 04:28
  • rms
    rms
    Posts: 606 from 2004/11/27
    I use the Pioneer DVD-R 109, DVD-R 110 and DVD-R 111 ant all are working very well with FryingPan and MakeCD.
    Regards
    Christoph
  • »15.01.07 - 04:43
    Posts: 2217 from 2003/2/24
    I have LG GSA-4167B and it works fine with MakeCD and FryingPan. I've tested DVD-R, +R, -RW and +RW with FP, all ok.
  • »15.01.07 - 05:30
    Kaczus
    Posts: 199 from 2003/9/6
    DVDRW:
    Samsung SH-S182MSB02 - works fine with fp.
    LG GSA-H22N1 - works fine with FP, but doesn't work quite good with morphos. (Morphos can't see any data on DVD)
    [ Edited by Kaczus on 2007/1/15 8:50 ]
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »15.01.07 - 05:49
    GK_LKA
    Posts: 481 from 2004/3/28
    I use an LG GSA-4160BA300 without any problems.
    [ GK / LKA Team ]
  • »15.01.07 - 07:05
    imax
    Posts: 41 from 2004/9/20
    Good joke !!!
    NEC5800 may only read CD/DVD.
  • »15.01.07 - 10:03
    FLComputer
    Posts: 22 from 2005/9/26
    Hi ;)
    I have tested Lite On and Nec DVD writers with Fryng Pan and it works great with Frying Pan.
    Pioneer I have tested has not done such as good results as Lite On or Nec.
    Bye ;)
    I.M.M. Informatique : YOUR Efika Reseller for France, Luxembourg and Belgium !
    Mail : laurentz@informatique-imm.lu
    Site : http://www.informatique-imm.lu
    ICQ : 81617715
    Skype : faranheit57
  • »15.01.07 - 11:36
    Golem
    Posts: 766 from 2003/2/28
    Well, he did say dvd-rom, and failed to specify what he expected makecd and fryingpan to do with the drive :-)
  • »15.01.07 - 14:29
    amiga4001
    I thought the drive couldn't write dvd's but does write cd's.
    Am I wrong..yes I presume.
  • »15.01.07 - 19:37
    AKiLL
    Posts: 93 from 2006/3/6
    Here my Philips DVDR1628P1 reader/writer works fine with MakeCD. I hope to get as soon a registered version of FryingPan so can use in the future for DVD wirting. Actually I regularly use it for dvd-writing using k3b under debian.
  • »15.01.07 - 20:06
    Posts: 108 from 2005/4/3
    Hi all,
    PHILIPS DVDR16LS Dual DVD with LIGHTSCRIBE, i burned a MorphOS
    boot CD with The Frying Pan.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »18.01.07 - 04:33
    A bit OT, but is it possible to burn DL-DVDs with FP and has someone allready done it???
  • »18.01.07 - 13:29
    FLComputer
    Hi all ;)
    Effectively, Frying Pan is able to manage Double Layer DVD !
    I have tested 2 DL DVD from Verbatim, and Frying Pan was able to burn 7,95GB of data on it, very slowly, but it worked.
    The DL DVD was totally readable on morphos !
    Very good job for this Software ;)
    Don't hesitate to contact me for registration's request.
    See you later ;)
    ICQ : 81617715
    Skype : faranheit57
  • »19.01.07 - 17:50
