USB 2 and an external HD.
    matt3
    Posts: 784 from 2004/2/10
    Does anyone know how to resolve issues with USB2 and an external USB2 HD.
    I have tried 2 different USB2 cards 1 VIA and 1 NEC.
    Whenever I plug the drive in I think (errors are in another language) I'm getting read/write errors and kills the port. The drive works perfect in my USB2 port on my PC and in my USB1.1 port in my peg2 as well.
    Both cards give the same results.
    I have played with the class settings to try and make it work with no results.
    Any ideas?
    Matt
  • »15.12.06 - 01:06
    matt3
    Poseidon drops the unit dead and a System Requestor pops up with:
    UMSD:
    Lesefehler 42 bei Block 7743
    I'm given the option to Wiederholen or Abbrechen.
    If I Wiederholen nothing changes.
    If I Abbrechen another random Block appears.
    My log in Poseidon follows:
    0-poseidon.library: Root hub has been enumerated.
    0-poseidon.library: New hardware MOSSYS:Devs/USBHardware/ehciusb.device/0 added. Plug in, baby!
    5-poseidon.library: Reading string descriptor 1 (len 2) failed: illegal parameters specified (11)
    5-poseidon.library: Reading string descriptor 2 (len 2) failed: illegal parameters specified (11)
    5-poseidon.library: Reading string descriptor 3 (len 2) failed: illegal parameters specified (11)
    5-poseidon.library: Reading string descriptor 4 (len 2) failed: illegal parameters specified (11)
    5-poseidon.library: Reading string descriptor 5 (len 2) failed: illegal parameters specified (11)
    0-poseidon.library: New hardware MOSSYS:Devs/USBHardware/ohciusb.device/0 added. Plug in, baby!
    0-poseidon.library: Say hello to hub.class V3.2 (Root/external hub base class (MOS)).
    0-poseidon.library: Whoah! massstorage.class V3.2 surprised as Supports storage devices via usbscsi.device (MOS).
    0-poseidon.library: The door bell rang for hid.class V3.4 (Generic support for human interface devices (MOS)).
    0-poseidon.library: Welcome serialpl2303.class V3.1 (PL2303 serial adapter via serialpl2303.device (MOS)) to the party.
    0-poseidon.library: Don't laugh at printer.class V3.2 for Bidirectional printer driver via usbparallel.device (MOS).
    0-poseidon.library: Time has come for cdcacm.class V3.2 (USB modems via usbmodem.device (MOS)) to join the show.
    0-poseidon.library: Start blaming bootmouse.class V3.1 for helping at Support for mice/tablets in boot protocol mode (MOS).
    0-poseidon.library: Ain't bootkeyboard.class V3.0 useful for Support for keyboards in boot protocol mode (MOS)?
    0-poseidon.library: Say hello to rawwrap.class V3.2 (Simple USB bulk IO wrapper via usbraw.device (MOS)).
    0-hub.class: Hub with 2 ports successfully configured.
    0-hub.class: I'm in love with hub 'Hub (VIA Technologies, Inc./0001)'.
    0-hub.class: Hub with 5 ports successfully configured.
    0-hub.class: I'm in love with hub 'Hub (0000/00E0)'.
    0-hub.class: Hub with 3 ports successfully configured.
    0-hub.class: I'm in love with hub 'Hub (0000/0035)'.
    0-hub.class: Detected device 'USB-PS/2 Optical Mouse' at port 2. I like it.
    0-hub.class: Hub has added 1 device(s). That'll be fun!
    0-hid.class: Using HID Descriptor from initial configuration run.
    0-hid.class: HID the road, 'USB-PS/2 Optical Mouse'!
    0-OnlineSupport: Success! Returned complex data format (1280 bytes).
    0-poseidon.library: PoPo kicks ass.
    0-OnlineSupport: Success! Returned complex data format (124 bytes).
    0-hub.class: New device 'USB2.0 Storage Device' at port 2. Very nice.
    5-massstorage.class: GET_MAX_LUN failed: endpoint stall (4), retrying in 0.5secs.
    10-massstorage.class: GET_MAX_LUN failed: endpoint stall (4)
    0-massstorage.class: MSD 'USB2.0 Storage Device' LUN 0 available through usbscsi.device unit 0!
    0-massstorage.class: Removable Task started.
    0-massstorage.class: Mounted usbscsi.device unit 0 as UMSD:
    5-massstorage.class: Command (28000000 1E3F0000 2000FF88) failed:
    10-massstorage.class: Command status failed: response timeout (6)
    5-poseidon.library: Device USB2.0 Storage Device probably dropped dead!
    5-poseidon.library: Automatically disabling port for 'USB2.0 Storage Device' due lowpower/death event.
    0-hub.class: Zapping device 'USB2.0 Storage Device' at port 2!
    0-massstorage.class: 'USB2.0 Storage Device' retreated, pitful coward.
    5-hub.class: CLEAR_PORT_ENABLE failed: response timeout (6)
    0-massstorage.class: Unmounting partition UMSD
    0-massstorage.class: Removable Task stopped.
    Thanks for the help!
    Matt
  • »16.12.06 - 00:41
    tokai
    Posts: 1289 from 2003/2/25
    The error means:
    Read error 42 at block 7743.
    Retry (Wiederholen) Cancel (Abbrechen)
    (I guess the error is caused by fat95 which AFAIR hasonly german error messages ;)
    The question is why it happens. YOu could try to tweak massstorage settings for that device a bit and see if it helps. Different settings for "Simple SCSI" or "CMD6->CMD10" or "NAK timeout" could maybe help. But I never tried USB2 myself on the peg, so I don't have any experience here concerning it. Maybe someone else knows a bit more and can speak from experience.
    regards,
    tokai
  • »16.12.06 - 08:54
    roschmyr
    Posts: 211 from 2003/2/20
    @matt3
    you need a registered version of Poseidon
    look at platon42 comments
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=16&topic_id=4852&sortname=&sortorder=&sortdays=&viewmode=flat&order=0&start=20
  • »16.12.06 - 09:13
    Golem
    Posts: 766 from 2003/2/28
    If you use the supplied installer those error messages can be in any language you like. (German, English, Spanish, French, Hungarian, Polish and Russian are supplied.)
  • »16.12.06 - 11:19
    matt3
    Hi Roschmyr:
    I don't think that is the issue here.
    The drive is dumped immediately after I plug it in.
    A flash drive works perfect with USB2.
    I will register if I can get this to run, but the only reason I pickup up the USB2 cards is to run my backkup faster. If I can't get it to work, I'm taking back the cards and will revert back to my PEG2 1.1.
    Take care,
    Matt
  • »18.12.06 - 10:12
    Golem
    Before I registered poseidon here, it would mount my flash drive ok, but my external hdd would be killed during mount (due to the larger fat table?). The flash drive would be killed after relatively little use though. How extensively have you used usb2 flash drives?
  • »18.12.06 - 12:28
    matt3
    Thanks Golem:
    I don't frequenlty use the flash drive at all. I copied over a small 20k file to test it and that all.
    I didn't realize that a large fat would not mount without registration.
    I will now register with Chris...
    I greatly appreciate the quick help.
    Merry Christmas!
    Matt
    [ Edited by matt3 on 2006/12/19 21:46 ]
  • »19.12.06 - 22:30
