Posts: 451 from 2006/11/16
I am rehousing my pegasos2 into a Aopen case.
It has 2 usb connectors on the front with should be connected with an internal plug.
The plug won't fit but there are single plugs which I can connect to the peg2 internal usb connection.
But which wire goes where?
The label on the usb cable says:
black---usb pwr brown---usb pwr
orange---usb0- green---usb0+
red------usb1- yellow---usb1+
gray---ground
On pegasos:
pin 17---usb+
pin19--- DMI 1
pin21--- DP1
pin23----usb -
please some advice before I blow something up!
