Pegasos 2 - Not working...
    amigaguy
    Posts: 15 from 2006/11/6
    I got the Peg2 I had ordered today...
    It doesn't seem to work though. Black screen. The speaker doesn't make a biip... and the harddrive doesn't spin up.
    I've tried 3 different graphics cards (7000,8500,9250) and 3 different DDR266 bricks.
    I've tried disconnecting all unnessecery components/wires.
    I guess it's just my luck. A defective mb/cpu.
  • »15.11.06 - 22:46
    Genesi
    Posts: 239 from 2005/1/7
    Hi, could you send us an email with a few more details.  :-)
    If the board is not working it will be replaced or repaired, but before you send it back let us try to troubleshoot the problem.
    OK? Thanks! We are standing by...
    R&B  :-)
  • »16.11.06 - 00:55
    Posts: 2539 from 2003/2/24
    Did you try looking at the serial debug-output ?
  • »16.11.06 - 02:17
    Neko
    Posts: 301 from 2003/2/24
    Please make sure the CPU card is well seated.
    New boards and new connectors are always a bit snug.
    After that, well, check the serial debug output. That will tell you if it is dead-dead (i.e. no output), if something is merely seriously wrong (it will say "IKARUS low-level console" and a give a prompt) or just what exactly is "failing" during the early startup process.
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »16.11.06 - 11:31
    Posts: 2077 from 2003/6/4
    Do not forget to check a different PSU. Power supplies are sometimes probelmatic. Even if they pretend to provide power on some maschines, they can fail on other maschines.
  • »16.11.06 - 11:57
    amigaguy
    Really nice to see that Genesi is willing to help and offer repairs/replacement. Not like some other company I know about :)
    When my MicroA1 suddenly died it wasn't much more I could do about it with Eyetech being unresponsive and all.
    I will send you (Genesi) an E-mail with all the details.
    To the other responses:
    - Tried 2 different PSUs as well.
    - I'm pretty sure the CPU is well fitted in the CPU slot.
    - What software and settings do I need to use on the (ahem) PC to get debug info from the pegasos serial?
    Amigaguy
  • »16.11.06 - 21:36
    Senex
    Posts: 500 from 2003/2/17
    Personally, I've used Tera Term Pro on the PC (link).
    Settings: 115200, 8n1
  • »17.11.06 - 04:56
    Posts: 140 from 2003/9/16
    Genesi support its even better than you can wish
    Once you are in touch with them, you will wonder, why oh why all companies are not the same way
    Just help them to help you :)
    [ Edited by FrankBrana on 2006/11/17 10:04 ]
  • »17.11.06 - 09:01
