Strange ethernet problem
    JohnFante
    Posts: 163 from 2006/9/4
    ? updated my Debian install last night. It was the first time I did it so it had to download around 1 GB.
    Everything worked ok thou and it booted nicely again.
    After the update the via ethernet port did?nt work. Both in Debian and MorphOS !!!!
    I tried the gigabit port to see if my router had given up but that worked fine, so it was that.
    Rebooting did'nt help and it was first after I turned of the computer and removed the powercord for 5 seconds that the via port came back to life again.
    Is this a normal problem and is there a better way than removing the powercord to solve the problem?
    Just vondering!
  • »07.11.06 - 07:45
    Wishmaster
    Posts: 342 from 2003/6/29
    Try the viarhine_wakeup tool.
    Pegasos PPC
  • »07.11.06 - 08:26
    hooligan
    Posts: 1948 from 2003/2/23
    Try the VIA Rhine patch:
    http://www.pegasos.org/index.php?name=Downloads&req=viewdownload&cid=5
  • »07.11.06 - 08:30
