Posts: 1289 from 2003/2/25
Hello JohnFante,
first of all to avoid confusion: Ambient is just the Desktop (the application which displays the icons and lets you launch other applications and manage your files). It's just another part of the OS like Audio/AHI or Poseidon/USB stuff. So updating Ambient doesn't update Poseidon or AHI.
About your problems:
If you want to mount FAT USB drives with Poseidon you must install fat95 from Aminet (www.aminet.net). Just copy "fat95" file from the archive to SYS:l/ (SYS is your System partition). Then it usually works.
For the audio problem: check if you have PegasosMixer in your SYS:wbstartup/ drawer and it is properly configured. If that isn't the solution I need more details what exactly doesn't work in your audio setup (tried to launch just Kaya or AmiNetRadio and play a mp3?).
regards,
tokai
