Posts: 2732 from 2003/2/24
@ macsrule
Welcome to MorphZone!
1. in terms of hardware, what is pegasos II? it almost seems like the pegasos II is just a motherboard, with a G4 cpu card. is this true?
Yes, it is a motherboard with a G4 CPU card. It is also available as a complete system, the Open Desktop Workstation (ODW).
2. i found a site that sells pegasos II's, but the g4 that comes with it is limited to 1ghz. is there a way to get a faster g4, or perhaps a g5?
The single 1GHz G4 is the fastest CPU currently available. The CPU's comes on replacable CPU cards, so they can very easily be replaced. Everyone has been waiting for faster CPU's though, and hopefully some upgrades will be available soon!
3. is there usb 2 support?
Yes, if you put a USB 2 PCI card in it!
4. does it come with a graphic card, or do i have to supply that?
As mentioned above, you can either buy a motherboard+CPU bundle only, or you can buy complete systems.
6. does the pegasos come with a case?
If you want to!
As mentioned above, it depends on whether you buy a full system or not. There is no official *Pegasos only* case, like on the Mac.
Quote:thats all i can think of right now, but if anyone else has any advice for someone switching from Apple PPC to pegasos ppc, please share it
Well, you may find info about the Pegasos PPC (and ODW) here, info which includes technical specs and where to buy:
http://www.pegasosppc.comThe Pegasos will soon be carried by the big online store
Directron.com. The price is then expected to come down compared to where it is today. I don't know when they will start taking orders, or how much it will cost, but feel free to ask them directly!
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
