which tool to test memory modules ?
    serge
    Posts: 725 from 2003/2/20
    which tool can I use to test memory modules ?
  • »07.11.04 - 13:51
    marcik
    Posts: 268 from 2003/4/12
    MemTest (it's in MOSSYS:C/)
  • »07.11.04 - 15:44
    tokai
    Posts: 1289 from 2003/2/25
    yes, memtest works very well... if you have many partitions etc. try to boot from cd, maybe even w/o HD connected (hd buffers etc. are using memory too), so that as much as possible memory is free then make the test with memtest.
    I also suggest to use the DELAY parameter, e.g. DELAY 10 waits 10 seconds between writing and reading/verify that way you can detect delayd bit switches.
    regards,
    tokai
  • »08.11.04 - 21:10
